Exhaust
hillmanseeker
PostPosted: Thu Apr 02, 2015 6:53 pm    Post subject: Exhaust Reply with quote
Hi, Any tips for straightening out part of a Exhaust? Can it be heated and moved with a steel pole inside? Or will it be easier to cut off and add straight pipe section?
Thanks everyone,
Dave.
PostPosted: Thu Apr 02, 2015 11:15 pm    Post subject: Reply with quote
Thin wall pipe is difficult to form without proper tooling, I've never tried to straighten as the wall would crush. I would cut out and weld in a new section.
ka
PostPosted: Fri Apr 03, 2015 6:54 am    Post subject: Reply with quote
I echo the previous statement, you will never successfully straighten out exhaust pipe.
KA
Better three than four.
Minxy
PostPosted: Fri Apr 03, 2015 10:37 am    Post subject: Reply with quote
In case you needed someone else to confirm it...........
