Singer Gazelle 111c/Hillman Minx disc brake conversion?
bobskie
PostPosted: Fri Jun 26, 2015 9:10 pm    Post subject: Singer Gazelle 111c/Hillman Minx disc brake conversion? Reply with quote
Anyone know if it is in any way shape or form possible to convert the singer Gazelle 111c/Hillman minx to front dsisc brakes? It must be possible somehow. I'm just curious probably won't actually do this it sounds like it would be a big job Very Happy
PostPosted: Fri Jun 26, 2015 9:24 pm    Post subject: Reply with quote
My singer vogue mk3 is disk brake.
Perhaps the front set up would swap over?
Kev
bobskie
PostPosted: Fri Jun 26, 2015 9:36 pm    Post subject: Reply with quote
Kev
Possibly, can anyone confirm this would work? Would be good to get some more modern brakes! Very Happy
steamtrainrunnin
PostPosted: Fri Oct 02, 2015 10:12 pm    Post subject: Reply with quote
Hi there i will let you know how i get on i have a gazelle 3a & i need to get disc brakes i cant see it being a major job just got to find the correct parts,just finished brake overhaul (total) on my camper van now my car is next its a rolling resto will post some pics hope you still have yours
Jim (Brighton)
ka
PostPosted: Sat Oct 03, 2015 8:41 am    Post subject: Reply with quote
The critical point is the caliper mounting, so the correct selection of the hub is essential. Many different set-ups over the years, but as already indicated, if you can rob hubs from a later model, the work will be a lot easier.
KA
Better three than four.
PostPosted: Sat Oct 03, 2015 8:57 am    Post subject: Reply with quote
It should be easy because all the Rapiers/Alpines from 1960 onwards have front disc brakes and use the same front cross member.
1939 SS Jaguar 2 litre saloon
steamtrainrunnin
PostPosted: Sat Oct 03, 2015 12:07 pm    Post subject: Reply with quote
Hey guys thanks for your comments have taken on board just walked up to speedy spares two minutes from home & they are closed GRRRRRRRRRRRRRRRR still lots of nice bits in the window display,i have put the word around to the banger boys i know & i'm sure they will get back to me still keep the comments & advice come all will help cheers Jim (Brighton)
JohnDale
PostPosted: Mon Feb 08, 2016 3:40 pm    Post subject: Reply with quote
Speedy Spares is one of the most likely places for info & good to deal with.
They are also on-line.Cheers,JD.
1976 Ford Granada Ghia.
