Polypedates
Posted: Sat Oct 03, 2015 5:22 pm Post subject: Brakes stuck - Citroen CX |
After a few months work I really thought I'd get my 1979 Series 1 CX Athena on the road this weekend. I finished off all the remaining jobs and just had to bleed the front brakes to be done. Despite following the manual to the letter the brakes are now locked solid and will not move. Releasing the bleed valves releases more hydraulic fluid so it is like full braking force is still being applied by the system even though the pedal is released.
Any one have any ideas on what the problem might be as I am stumped? |
Posted: Sat Oct 03, 2015 5:30 pm Post subject: |
Did you replace the front flexible pipes?
I have heard of instances where the lining comes adrift and does allow fluid to flow backwards to the MC. _________________ Bristols should always come in pairs.
Posted: Sat Oct 03, 2015 6:14 pm Post subject: |
I assume these are discs?
In which case you need to lever the wheel cylinders in. Actually it has just struck me that in my BX there was some form of auto adjustment for pad wear because the handbrake also operated on the front wheels. I think your best bet would be to get hold of a workshop manual (even a Haynes one) and take a look at the auto adjust mechanism.
Polypedates
Posted: Mon Oct 05, 2015 6:00 pm Post subject: |
Thanks for the replies. I did not renew the brake hoses as they looked OK so will investigate those.
Yes it is disc brakes with a mechanical handbrake on the front wheels operating via a separate set of pads. I assume there is something in the hydraulic system that is meant to govern pressure to the brake circuit and its release but I don't know what.
A perusal of the Haynes manual at the scene did not yield any enlightenment. I'll read the hydraulic and braking chapters in full and see if I can piece together the likely culprit although I'd prefer a diagnosis before taking the hydraulics apart! |
