JohnDale's Humber Sceptre
Goto page Previous  1, 2
JohnDale
PostPosted: Fri Apr 15, 2016 9:23 am    Post subject: Reply with quote
bob2 wrote:
Wow quite a lot of work then!!
Hi Bob, yeah, & I'm getting(got) too old for it. Also heard noise from the water pump so have just fitted a new one. Some 'STAR' mechanic been on this car at times - two of the 1/4 UNC bolts holding the two halfs of the pump together had been sheared - easily fixed by said star mechanic - just fill the holes with sealer!!! Now drilled out & re-tapped. He(or she) had also found a seized inner piston in the near side caliper when fitting new(wrong) pads.That's OK,easy job,just put a worn pad in the inner & new in the outer.
Job sorted. All the best,JD.
1976 Ford Granada Ghia.
bob2
PostPosted: Mon Apr 18, 2016 8:52 am    Post subject: Reply with quote
hmmm seems like a very nice car ruined by an icompetent!!
At least you are getting it right now so it looks nice and drives nicely too!
JohnDale
PostPosted: Wed Jun 22, 2016 4:31 pm    Post subject: Reply with quote
Humber has now gone to Liverpool(sorry Bob2) as I got the chance of something more to my liking(& a lot rarer). I will need to change my avtar & post some pix. Shush Peter(Scott), keep it quiet a little longer. Good to see you again at Bridge of Allan,cheers,JD.
PostPosted: Wed Jun 22, 2016 5:58 pm    Post subject: Reply with quote
Mums the word! ...and the other word is Thirlestane.
Peter Wink
1939 SS Jaguar 2 litre saloon
JohnDale
PostPosted: Mon Jun 27, 2016 3:47 pm    Post subject: Reply with quote
Yes it was Peter,sorry! It's an age thing when all shows blend together. all the best,JD.
JohnDale
PostPosted: Fri Nov 17, 2017 4:52 pm    Post subject: Reply with quote
Corsair Estate is also now sold due to other things going on in my life.
It will be going to NewZealand with a wee detour to Chelmsford first.
New owner splits his time between UK & NZ. Cheers,JD.
Page 2 of 2
