TM8
Joined: 24 Feb 2013 Posts: 53 Location: Pretoria, South Africa
Posted: Mon Apr 11, 2016 5:58 am Post subject: Morris 8 Two Seater Rear Section Help |
Hi all i am having some issues with the rear timber floor section. I didnt have a sample to go on so i simple followed the chassis leg thinking i would pull the rear fender in and bolt up but i am thinking the timber should hang over the chassis leg. Any body got dimensions between the rear fenders or a dim showing how much i should hang over the chassis leg each side? Thanks Trevor
bjacko
Joined: 28 Oct 2013 Posts: 358 Location: Melbourne Australia
Posted: Mon Apr 11, 2016 6:51 am Post subject: Morris * rear end |
Trevor,
If you look at "Morris 8/40 Tourer Restoration" in this forum you will see some pictures of a four seater rear end and I would think the two seater would be similar. |
