shmbry
Posted: Mon May 09, 2016 9:39 pm Post subject: Identifying wheel bearings |
Has anyone seen wheel bearings like these?
The markings are;
IL JT 31 7
and the dimensions are;
62mm OD x 32mm ID x 16mm wide
They are from my 1981 Castleton on an Ambergate Engeering chassis.
There are two of these thrust bearings per side with a distance piece between them.
I am looking for new ones or direct replacement alternatives. |
Posted: Tue May 10, 2016 1:01 pm Post subject: |
They look like angular contact bearings - check out
RHP 16/LJT1-1/4 Angular Contact Bearing 31.75x62x16mm at Simply bearings. It looks as if your bore is 31.75 not 32. |
