ALW Ford Popular
Posted: Tue Jun 07, 2016 8:10 pm Post subject: |
Thanks KA, have sent you a PM in case you can help. Many thanks again,. |
ALW Ford Popular
Posted: Sat Jun 18, 2016 12:53 pm Post subject: |
So - thanks to all for replies and help. New old stock standard con rod now located and fitted !
Should the gudgeon pin be a tight fit into the piston?? Mine all have the ability to rotate (but tightly) which surely will then have a chance that it will use the piston as a bearing rather than the bush in the con rod?? |
ALW Ford Popular
Posted: Mon Jun 27, 2016 9:04 pm Post subject: |
So no advice on the pins - so fitted as they were, all movement seemed fine on the small end, could rotate the pins by pushing them round.
Anyway - have just tracked down a pair of trafficators that align perfectly with the slots in the body. AND they work !!!!
Will be fitting them shortly. So - they are TRICO and I have the dimensions if anyone has a Pop or and Anglia and has the car with slots in that need filling with light units.
Progress !!!
Off to flush the fuel tank and refit sump. |
ka
Posted: Fri Jul 01, 2016 7:22 am Post subject: |
The gudgeon pin should be an interference fit in the pistons, and fit in the little end with movement. The bush in the little end has oil entrance slots allowing it to rotate in the reciprocating manner. If there is play in the pistons then either new pins or/and pistons, The pistons have no bushes and no allowable wear factor. _________________ KA
Better three than four. |
ALW Ford Popular
Posted: Wed Jul 06, 2016 5:36 pm Post subject: |
So - today - new battery, checked timing, checked electrics, cleaned out tank, cleaned fuel line (did carb a while ago).
Turned over fine, with choke out carb literally poured petrol into the manifold !!
With choke in it started and ran, bit lumpy.
Put on rubber glove and tweaked distributor for best running.
Removed carb and stripped / cleaned, but still floods with choke out.
Any ideas ??
Sounds great by the way and very happy - last ran over 43 years ago.
Drives, clutch bit juddery, may improve with use. |
Posted: Thu Jul 07, 2016 10:35 am Post subject: |
First check would be to see if the float in the carby is intact. Even a small pinhole will admit petrol and allow the float to sink, therefore opening the needle valve and admitting extra fuel.
Shake the float to hear if there is liquid inside. A more positive test is to totally immerse it in hot water and look for bubbles.
Assuming an intact float, and that the float height is correct ( adjusted by linkages in some carbys) then the only other probability is a leaking needle and seat assembly. These can usually be bought fairly cheaply and take moments to fit.
Dane. _________________ Dane- roverdriver but not a Viking. |
ALW Ford Popular
Posted: Sat Jul 09, 2016 10:22 am Post subject: |
Thanks Dane,
But it is not flooding with choke in. Only when choke selected.
I am going to recheck all air holes on starting venturi. When you pull the choke it literally fills the manifold with fuel !!!! |
ALW Ford Popular
Posted: Mon Jul 11, 2016 12:32 pm Post subject: |
Thanks for the diagrams. I have stripped, cleaned and carefully checked all jets and fittings and all seems correct. Float is dry and floats !
Have got a replacement emulsion block gasket to fit and then will go again.
Can't see how fuel could flood only with choke out, unless float level is wrong, but it doesn't flood with choke in !!!
Love the vehicle now that it works ! Pleased that all the bits came right. |
Posted: Mon Jul 11, 2016 4:01 pm Post subject: |
You should perhaps remember that the choke is not an on/off device but an adjustable one. If it floods with full choke, try it with half choke and see how that goes.
Art |
ALW Ford Popular
Posted: Tue Jul 12, 2016 3:50 pm Post subject: |
Hi, yes thanks for the details. I think that having replaced the gasket and stopped the leak, it is 'user error'.
I am used to pulling choke out fully and starting then returning slowly. More like a usual butterfly arrangement. However, this carb is different and has a separate starting carb essentially !
Incidentally, is it usual for fuel to collect at the base of the inlet manifold on the join to the exhaust? Is this me overchoking it??? Must learn to drive this thing properly!! |
ALW Ford Popular
Posted: Sun Jul 31, 2016 8:59 pm Post subject: |
So now up to perfecting the running. Using a vacuum gauge I thought !
But - gauge flickers violently all over the place and so I can't set ignition or mixture etc. Have tried a restrictor and it still does it - does this mean that valves or guides or something else - or could it be the type of gauge? Are some more sensitive than others ???
Other than that it is now running really well. Off to get it cleaned underneath then regrease and check out gearbox mounts as a slight vibration on pull away. May just be a rusty clutch. |
Posted: Sun Jul 31, 2016 11:27 pm Post subject: |
ALW,
Have you done a compression test. This would be the first test to run.
There's loads of stuff on vacuum gauge testing on't 'net. Here's an example
http://www.classiccarhub.co.uk/articles/tuning-and-fault-finding-using-a-vacuum-gauge.html
What some of the readings mean.
gauge reading steady 17-22 in Hg indicates normal engine in good condition.
gauge reading low (15-20 in Hg) but steady indicates late ignition or valve timing, low compression, stuck throttle valve, leaking carburetor or manifold gasket.
gauge reading steady but dropping regularly indicates burnt valve or improper valve clearance.
gauge reading dropping gradually at idle indicates choked muffler or obstruction in exhaust.
gauge reading slowly dropping to zero as engine speeds up indicates choked muffler.
gauge reading fluctuating between 15 and 20 in Hg at idle indicates stuck valve or ignition miss.
gauge reading drifting indicates improper carburetor adjustment or minor intake leak at carburetor or manifold.
gauge reading fluctuating as engine speed increases indicates weak valve springs, worn valve stem guides.
gauge reading vibrating excessively at idle but steady as engine speeds up indicates worn valve guides.
gauge reading vibrating excessively at all speeds indicates leaky cylinder head gasket.
Art |
ALW Ford Popular
Posted: Tue Sep 13, 2016 4:55 pm Post subject: |
Car running well now. Carb strip and new gaskets did the job.
Been over and steam cleaned underside to see what I have actually got under there !
Does anyone know what the wing piping is made of please and where to get ?
Also - headlining material - it is soft - and very dirty !
Thanks
Andrew |
