Posted: Sun Mar 26, 2017 2:25 pm Post subject: |
Steve,
[/quote]got about 30 ohms [quote]
That looks good, what I would expect. I know I'm stating the obvious but you have checked the F1/F2 fuse?? I would be looking at the main switch I think. Whatever goes on in there. I'll have a read up online and see if I can be of any further help.
Art |
Posted: Sun Mar 26, 2017 11:40 pm Post subject: |
Steve,
Do you know/can you look at where the 3rd brush is located. If it is close to the brush that goes to the D terminal then we should be earthing the F terminal to get max output. We may have sold you a pup with the previous advice. Have a look and get back.
Art |
stevefizz
Posted: Mon Mar 27, 2017 3:08 pm Post subject: |
Seemed a bit better but still needed about 2000 rpm before the ing. light went out
just as a test turned the head switch on
i guess because i dont have any headlights connected i got more amps then i should and it blow the regulator 3amp fuse |
stevefizz
https://goo.gl/photos/EcDfyYHD33Mo2ocL7 |
Posted: Mon Mar 27, 2017 6:54 pm Post subject: |
Steve,
Excellent, we're making progress then Check what voltage you are getting just below 2000rpm. All we need is about 12.5 volts which hopefully would be about 1000-1250rpm. As I said previously the cut-out cut-in may need adjusting. Looking at your picture I can't see an obvious adjustment. You could try closing up the air gap by bending the tang on top of the cut-out armature to about 25 thou. If there is a coil spring pulling on the armature then loosening the hook the spring atttaches to will lower the Cut-in point. If it's a blade spring then bend where the blade rests on.
I know that this isn't the original Dynamo but how do the pulleys compare. Is the original perhaps a smaller diameter?
Art |
stevefizz
stevefizz
DM
Joined: 21 Dec 2008 Posts: 212 Location: North Cornwall
Posted: Mon Apr 03, 2017 7:34 pm Post subject: |
At least you got the right date on the photo even though you were slow to post it |
Posted: Mon Apr 03, 2017 7:41 pm Post subject: |
Steve,
I'm glad that you have found the problem. I would suggest you shorten the new wire or at least coat the wire with some sort of adhesive to counter the centrifugal forces.
Art |
