Just bought a Pop 103e, 1957
Goto page Previous  1, 2, 3 ... , 15, 16, 17  Next
GARAGE HERMIT
PostPosted: Tue Apr 17, 2018 7:39 pm    Post subject: Reply with quote
made a new throttle pedal to operate the twin SU's, used a morris 1000 pedal and added a few more bend's and a skateboard wheel,
1957 - 103e - popular,
Paul fairall
PostPosted: Wed Apr 25, 2018 8:33 pm    Post subject: Reply with quote
Does all of it fit inside the car and a cable through the bulkhead?
1957 ford popular
GARAGE HERMIT
PostPosted: Thu Apr 26, 2018 12:13 pm    Post subject: Reply with quote
yes,
it was a bit of a faff on but work's a treat,
a few people i've talked to have used early mini pedal's too,
Paul fairall
PostPosted: Thu Apr 26, 2018 7:29 pm    Post subject: Reply with quote
GARAGE HERMIT wrote:
yes,
The wheel is a bit trick dude
1957 ford popular
PostPosted: Fri Apr 27, 2018 12:09 am    Post subject: Reply with quote
yes,
My first reaction to the photo was "VW!".
Early Beetles had just such a wheel. A common accessory was a flat metal pedal hinged to the floor & resting on the wheel.
2002 Mini Cooper 'S'
GARAGE HERMIT
PostPosted: Fri Apr 27, 2018 5:56 pm    Post subject: Reply with quote
thank's,
i'll put a dome nut on the end of the through bolt to tidy it up a bit,
GARAGE HERMIT
PostPosted: Wed May 09, 2018 6:08 pm    Post subject: Reply with quote
fitted some old style holiday sticker's,
fitted my new old style steering wheel,
mounted one front seat, still have to paint the mount's,
replaced the window seal's, that was a right mess on, still have the other door to do,
mounted the imitation ford 1930's rear light's, still have to blank off the original pop mounting hole's,
bought an old door knod to use as a gear leaver knob, i'll have to stain it to match the steering wheel though,
GARAGE HERMIT
PostPosted: Sun May 13, 2018 11:55 am    Post subject: Reply with quote
well good new's and bad new's,
good new's is managed to get the SU carb's balanced and running right, they're quite finiky to set up, for me anyway,
bad new's is there's a hairline crack in the engine block (pic) the water isnt running out more of a weep, the clutch is slipping like a goodun, and the steering box is very worn, very nerveracking drive,
so what to do, to sort out these problem's is going to cost a few quid, and quite a bit of work, so i'll have to have a think, bugger,
PostPosted: Mon May 14, 2018 7:37 am    Post subject: Reply with quote
Is there any adjustment left in the steering box?
Rick (OCC Admin)
GARAGE HERMIT
PostPosted: Mon May 14, 2018 10:24 am    Post subject: Reply with quote
no, i've adjusted it, no real improvement, i've been given an address of a s/box refurb firm, so see what they say,
alanb
PostPosted: Mon May 14, 2018 11:17 am    Post subject: Reply with quote
1 and a half inches either side of centre measured at the steering wheel rim is considered acceptable, don't be fooled into comparing it with modern cars or with rack and pinion steering, the best steering box conversion is to use a modified VW box and column as used by the MG boys.
old tourer
Morris 8 two seater
PostPosted: Mon May 14, 2018 11:35 am    Post subject: Reply with quote
If there is any end float in the column that can cause lost motion. Look at the top of the column from the side and if your steering wheel moves in or out when you rotate it then that's fixable.
1939 SS Jaguar 2 litre saloon
GARAGE HERMIT
PostPosted: Mon May 14, 2018 8:48 pm    Post subject: Reply with quote
mine's a bit more than 1 1/2", yes i'm not comparing it with a modern car, i'm not un-nerved by most driving scenario's having ridden a motorcycle for over 45 year's, but this thing is leathal,
the VW box mod sound's interesting, do you have any more information on it please,
GARAGE HERMIT
PostPosted: Mon May 14, 2018 8:49 pm    Post subject: Reply with quote
no end float, i adjusted the cup & cone ball race, not too tight not too loose,
alanb
PostPosted: Mon May 14, 2018 10:54 pm    Post subject: Reply with quote
There are others but this is the first I came across, http://www.mg-parts.co.uk/index.php?route=product/product&product_id=82
When I said one and a half inches either side of centre that is three inches in total. My Morris 8 has about an inch either side and that is on a refurbished box, if the tracking and camber angles are correct then it shouldn't be a problem as the car should centre to a straight line with little wander, also make sure there is no lost motion in the drop links and track rod bushes. Still I suppose they didn't call them puddle jumpers for nothing!
old tourer
Morris 8 two seater
Page 16 of 17
