Paul fairall
Posted: Fri May 12, 2017 4:14 pm Post subject: |
GARAGE HERMIT wrote: | thought there was someting strange about the front suspension set up on my pop, it did'nt look like any of the pic's in the book's and manual's i have, just found out it's a Bowden IFS, in 1959 it cost £20.00, it was a straight bolt on mod, a nice surprise, should ride even better when i fit the Woodhead shock bracket's and shock's,
| £20? Give yer fifty quid for it. _________________ 1957 ford popular |
GARAGE HERMIT
Joined: 20 Mar 2017 Posts: 186 Location: stockton upon tees, cleveland,
Posted: Fri May 12, 2017 7:50 pm Post subject: |
thank's for the offer paul, but no thank's,
here it is on the car, all the black stuff is underseal,
_________________ 1957 - 103e - popular,
Last edited by GARAGE HERMIT on Thu Sep 20, 2018 2:53 pm; edited 2 times in total |
GARAGE HERMIT
Posted: Fri May 12, 2017 7:55 pm Post subject: |
made some bracket's out of a bit of angleiron i had in the garage, fitted a spotlight, Notek nearlite, and a foglight, Miller tungsten iodine,
_________________ 1957 - 103e - popular, |
GARAGE HERMIT
Posted: Fri May 12, 2017 8:07 pm Post subject: |
gave the dynamo a good dig out, greased the bearing and found a blanking grommet that fitted the bearing end, someone had fitted a new phospher bronze bearing, but had'nt drilled it to allow the oil wick to touch the armature shaft, so i did, plus a lick of paint,
GARAGE HERMIT
Posted: Fri May 12, 2017 8:16 pm Post subject: |
bought an export petrol pump, thinking it will pump a bit more petrol as i'm fitting the twin SU's, it is rather large, hope it wont foul anything,
GARAGE HERMIT
Posted: Fri May 12, 2017 8:34 pm Post subject: |
Last edited by GARAGE HERMIT on Wed May 31, 2017 11:23 pm; edited 1 time in total |
Paul fairall
Posted: Sat May 13, 2017 8:39 am Post subject: |
Should that main leaf spring be that flat. I know your suspension set up is different to standard but mine was on the bump stops and the spring was not as flat as yours. _________________ 1957 ford popular |
GARAGE HERMIT
Posted: Sat May 13, 2017 9:56 am Post subject: |
paul,
i dare say after 60 year's the spring has lost a bit of it's spring, same as me lol, but you can see in the pic there's about 5" from the spring and the bump-stop, so i think it'll be fine, i've no plan's to mess about with it at the moment, _________________ 1957 - 103e - popular, |
Paul fairall
Posted: Sat May 13, 2017 1:18 pm Post subject: |
GARAGE HERMIT wrote: | paul,
i dare say after 60 year's the spring has lost a bit of it's spring, same as me lol, but you can see in the pic there's about 5" from the spring and the bump-stop, so i think it'll be fine, i've no plan's to mess about with it at the moment, | your suspension set up is different from mine I doubt it could ever hit the bump stops. If it rides ok happy days. _________________ 1957 ford popular |
Posted: Sun May 14, 2017 5:01 pm Post subject: |
I have a more modern alternator [cannot recall what it came off, sadly..but it has a in-built diode regulator pack, rather then needing a separate one]....Paul Beck sent me [ a long time ago now] a pulley from a Ford Pilot....I needed to retain the big heavy combine harvester drive belts....I ground off the cast iron fins, and it mounted nicely on the alternator shaft [many have different sizes]....mounted low on the right side of the engine bearer.....was/am reluctant to hang dynamos or alternators off the cylinder head nuts...for obvious reasons...
The car it was/is in being a low special, the 10 hp engine was happy enough with a Mini radiator, laid on it's side.....and a large tee planted on the cylinder head .....t'uther end going to a home made header tank....engine ran cool enough with this...and an electric fan bolted in front [FIAT, IIRC?}....oh, it had a Ford export water pump....although I experimented a bit with one I believe came off a Maestro/Montego...[?]....which was the only separately-mounted water pump I could find in the scrappies....? [IE, one that was not involved with the cylinder block]
I'm now looking at trying out one of those electric water circulators found in modern VAG motors..small, plastic, might work, if I can find a suitable plug for it? I'm not afraid of making use of common modern technology, honest.
Anyone tried single point fuel infection on a Pop? |
Paul fairall
Posted: Sun May 14, 2017 9:32 pm Post subject: |
I bought my dynamator ( alternator in a Dynamo case ) from car builder solutions, also plenty on eBay, the C39 C40 use the correct size spindle for the original pulley. I plan to remove the fan blades at some point and fit an electric fan and electric water pump, again plenty of those available from eBay, that's if I find it really necessary. _________________ 1957 ford popular |
GARAGE HERMIT
Posted: Sat May 20, 2017 10:35 am Post subject: |
classicars,
thank's for the pic,
cant really tell what the profile is of your door moulding in the pic, have you a better pic, or could you tell me where and what you bought,
there's so many to choose from,
thank's GH, _________________ 1957 - 103e - popular, |
GARAGE HERMIT
Posted: Mon May 29, 2017 11:20 am Post subject: |
took all the valve's out to have a look at the condition, good job i did, all the seat's are pitted, 3 are really bad, i'd be lapping them till next year, anyone know of a good hand valve seat cutter i could buy,? _________________ 1957 - 103e - popular, |
GARAGE HERMIT
Posted: Wed May 31, 2017 11:07 pm Post subject: |
fitted a pre-war smith's mechanical 8-day clock the other day,
Last edited by GARAGE HERMIT on Thu Sep 20, 2018 2:56 pm; edited 2 times in total |
GARAGE HERMIT
Posted: Wed May 31, 2017 11:12 pm Post subject: |
prefect wheel's before,
and after,
difference in width between the pop tyre's and the prefect 16" one's, nearly 2" more rubber on the road, and they are radial's,
Last edited by GARAGE HERMIT on Wed May 31, 2017 11:28 pm; edited 1 time in total |
