Positioning of carburettors.
Kleftiwallah
PostPosted: Tue May 30, 2017 8:29 pm    Post subject: Positioning of carburettors. Reply with quote
Soon...I shall be attempting to mount two Solex 26FV carbs onto a Hotchkiss aircooled V twin. Am I correct in thinking that if the float chamber is below the level of the fuel tank I will not need a fuel pump? ? ?
More questions to follow...
Over to you knowledgeable peeps. Cheers, Tony. Rolling Eyes
billysugga
PostPosted: Tue May 30, 2017 10:19 pm    Post subject: Reply with quote
Is the tank outlet on the bottom or top of the tank?
Because you may have to create a syphon.
If the outlet is on the bottom then no you shouldn't need a pump.
What is the engine out of? Any pics?
Volvo Sugga ,Volvo Trygge
I just wish one was working!
PostPosted: Wed May 31, 2017 9:02 am    Post subject: Reply with quote
In principle the answer is yes! Fit a shut off tap to the tank though!
Kleftiwallah
PostPosted: Wed May 31, 2017 12:51 pm    Post subject: Reply with quote
The fuel rmerges from the bottom of the tank, there is already a valve fitted to the tank.
Thanks for those helpful anwers. Cheers, Tony.
'Tis in (or soon will be) a BSAFWD TW31.
