MattF
Joined: 29 Mar 2013 Posts: 86 Location: Christchurch, NewZealand
Posted: Fri Jun 30, 2017 6:28 am Post subject: Starting problems s1 8 |
About two and a half years ago my s1 8 was running, since then she's been garaged. Back then she was a two spin hand start from cold and now in trying to get her running again she will sometimes fire up roughly for a few seconds-1min and then die. All the plugs spark but I'm not sure they spark that well (don't know much about plugs) I have petrol flowing ok and no blocks in the air supply. Any ideas what I should do? My only thought was try tow it around the block a few times to get the oil moving? Other than that I'm at a loss to know what the problem could be |
Miken
Posted: Fri Jun 30, 2017 12:24 pm Post subject: |
Is the fuel in the tank 2 1/2 years old? |
MattF
Posted: Fri Jun 30, 2017 12:49 pm Post subject: |
Haha sorry should have said I have drained the tank, cleaned out the float chamber and refuelled before trying to start her |
Posted: Fri Jun 30, 2017 2:56 pm Post subject: |
Possibly the fuel already in the carb bowl is getting used up, and not being replaced?
Perhaps the needle valve on the carb is sticking? {Gummed up?] |
MattF
Posted: Fri Jun 30, 2017 9:55 pm Post subject: |
Thanks guys i know the needle is going up and down ok but will check petrol supply into the float chamber/carb.
In thinking about it there's got to be enough spark because at least half the cylinders are backfiring at me so I may have a timing problem also |
MattF
Posted: Fri Jun 30, 2017 11:08 pm Post subject: |
May have found the problem, just don't know what to do about it.
If I'm correct when you flood the float chamber and lift the piston inside the carb petrol should jet out the air-intake....not just flood the float chamber so much that it pisses out the nut at the top!!???? What part do I need to take apart and clean? |
MattF
Posted: Sat Jul 01, 2017 9:20 pm Post subject: |
Yay now she's going, after cleaning out the carb I still had to do the pull start option.
Now to see what's wrong with the side and tail lights - fingers crossed its just the fuse |
welder
Joined: 26 Nov 2007 Posts: 265 Location: North Warwickshire
Posted: Sun Jul 09, 2017 10:32 pm Post subject: |
MattF wrote: | Yay now she's going, after cleaning out the carb I still had to do the pull start option.
Matt, if fuse replacement isn't the cure take a look inside the circular connection box on the bulkhead, just beside the battery tray. I once had problems similar to yours and checking/tightening of all the brass screws sorted things out.
Ian |
