Super Minx clutch losing pressure
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10
TriciaS
PostPosted: Sat Mar 23, 2019 7:36 pm    Post subject: Reply with quote
V8 Nutter wrote:
It's simple fit the thrusts you have, then lever the crank as far forward as possible check the gap between the thrust washers and the crank that is your end float, if it's more than about .005 you need to do something about it. I can't remember what the book said end float should be, but I'm guessing about .002 to .006 should be about right
yes we did that and the gap is .004 and has to be between .002 and .008 so about right and cured the clutch problem for about 5 mins
V8 Nutter
PostPosted: Sat Mar 23, 2019 10:08 pm    Post subject: Reply with quote
If it only worked for about 5 minutes, that is probably because the main cap is too damaged to hold the thrust washer in place. If you take it apart again I think you will find the thrust washers are back in the sump.
TriciaS
PostPosted: Sun Mar 24, 2019 7:47 am    Post subject: Reply with quote
yes as I said I knew by the sound it was at least one but clutch still workiing not losing pressure so obviously only 1 fell in but had welded a bit on the bearing cap to hopefully stop it happening so presume it was the wear in the crank that made it fall out or not come out far enough on bearing cap
Page 10 of 10
