Old Jag fuel system - addendum
7D4
PostPosted: Sat Sep 16, 2017 6:52 pm    Post subject: Old Jag fuel system - addendum Reply with quote
I'm flying blind here without a manual. Check out the attached pic of the inside half of one of the air cleaners. What are the blind passages for? (The bulges that arch over the carb holes.) A 3/8" fuel line connects to the back.
Also curious is that a small bit of fuel dribbles out of that line AFTER I shut off the fuel pump. I can run the pump (aftermarket pump--not an SU) for 10 minutes and nothing comes out of that line, but less than a minute after turning it off fuel appears like a runny nose.
I know I'm getting good pressure because I failed to completely seal the filter bowl and made a mess in the spare tire well.
[img]http://photobucket.com/user/74jag/media/Hsmacks%20022_zpsxnog2g1v.jpg.html[/img]
7D4
PostPosted: Sat Sep 23, 2017 4:27 pm    Post subject: Reply with quote
While making a gasket I saw that those passages aren't blind after all.
Meanwhile I got it to start and run for almost a minute without any ether, giving me time to play around with the choke. It ran best with full choke. (The choke lever doesn't lock in that position.) It ran smooth so I have at least one carb on each side working.
I'm not sure why it quit. It would barely run on ether after that. I'll let it sit for a day and try again.
