Posted: Sun Sep 30, 2018 12:56 pm Post subject: |
Excellent, well done!!
Quote: | As you can imagine, I am over the moon! |
It didn't fall off the jack in top gear, did it.....???? _________________ Dellow Mk2, 1951 built, reg 1952.
Joined: 30 Apr 2013 Posts: 3805 Location: The Somerset Levels
Posted: Sun Sep 30, 2018 1:27 pm Post subject: |
No, i had it up on two 5 ton axle stands and I left the 3 ton trolley jack under the diff to be on the safe side! _________________ Various Rootes Vehicles. |
Posted: Mon Oct 01, 2018 7:44 pm Post subject: |
On this date BUT 110 yrs ago
1908-10-01 Henry Ford introduces the Model T car (costs $825) _________________ Bristols should always come in pairs.
Posted: Mon Oct 01, 2018 8:03 pm Post subject: |
Just think how cars have evolved in that 110 years. _________________ Various Rootes Vehicles. |
JohnDale
Posted: Thu Oct 11, 2018 5:10 pm Post subject: |
Rootes75 wrote: | No, i had it up on two 5 ton axle stands and I left the 3 ton trolley jack under the diff to be on the safe side! |
Looks like we're all busy - it must be that time of year.
Hi Folks, finally got started to try & cure the Zephyr's incontinence. Gearbox,overdrive & rear axle drained. Gearbox side plate removed & stripped,
new shaft lip seals & interlock spring fitted, refitted with new gasket. Overdrive selector shaft remove & new lip seal fitted. Rear axle appeared to have excess back lash so half shafts & diff carrier removed. Crownwheel & pinion backlash was spot on,with the problem being in the opposing gears of the diff. Made new copper thrusts & re-assembled to spec. New inboard lip seals fitted to rear axle to protect hubs/brakes(working through the diff carrier access - oh joy) New rear brake shoes fitted & half shafts refitted with new gaskets. Tested while jacked up to 50mph & all worked. No leaks but no oil filled yet so to be expected. Cheers,JD. _________________ 1958 Ford Zephyr Mk2 Convertible
1976 Ford Granada Ghia. |
Posted: Sat Oct 13, 2018 5:47 pm Post subject: |
Couple hours down the yard this morning, continuing the re-wire of the Commer. Its tedious. _________________ Various Rootes Vehicles. |
Posted: Sat Oct 13, 2018 6:43 pm Post subject: |
Bought a 8mm alu plate, cut it to fit the horizontal space between radiator and front end on the Jensen. Painted it.
Retrieved the bonnet and placed it upside down on the car lift. The edges are quite rusty which is fairly strange as the car has not seen much rain. Maybe it stood in a damp garage for a few years. Luckily it has not spread to the top of the bonnet. Hope to clean the edges tomorrow and put some pain on it. In the mean time I cleaned the hinges and painted them. _________________ a car stops being fun when it becomes an investment |
Posted: Sun Oct 14, 2018 4:19 pm Post subject: |
Another couple hours work this morning, finishing off re-wiring the sidelights. Got the new wiring linking back into the old control panel and now the sidelights work off the switch. Not bad considering all the wiring is new, I still need to sheeth the wiring under the front valance but I have fitted bullet connectors at points underside that I can easily get to to taking marflex between them is straightforward. _________________ Various Rootes Vehicles. |
Posted: Sun Oct 14, 2018 8:54 pm Post subject: |
De-rusted and primed the bonnet edges. Made a battery holder and painted that. Repaired the accelerator pump which was a great relief, the car had trouble starting from cold. A little valve was stuck. Using Youtube to find the cause was very helpful! _________________ a car stops being fun when it becomes an investment |
Posted: Sun Oct 14, 2018 8:56 pm Post subject: |
Rootes75 wrote: | I have fitted bullet connectors at points underside that I can easily get to to taking marflex between them is straightforward. |
What is "marflex" _________________ a car stops being fun when it becomes an investment |
Posted: Mon Oct 15, 2018 7:23 am Post subject: |
We use marflex where I work so I can bring rolls of it home. Its a woven type material that comes with an internal diameter of about 10mm. The outside of it has a heat and water resistant coating. So its ideal to feed electrical wires through it, especially on the underside of a vehicle to give it some protection. _________________ Various Rootes Vehicles. |
Posted: Mon Oct 15, 2018 7:40 pm Post subject: |
Beware of these, I don't think the bearings are much good. I overhauled a dynamo using a kit off fleabay but it wasn't long before it was as noisy as the old one with an annoying "tick" from the front bearing. |
Posted: Mon Oct 15, 2018 9:30 pm Post subject: |
Had some matching paint made and painted the edges of the bonnet. Frame (inside of the bonnet) sprayed with heat resistant matt black paint.
Noticed the carburetor is leaking. Ah well... my todo list was getting too short so happy this came up _________________ a car stops being fun when it becomes an investment |
