BigJohn
Posted: Mon Feb 19, 2018 8:30 pm Post subject: |
I only use about 5-8psi in an Eezibleed. The can be incredibly messy if they leak under pressure. |
Posted: Mon Feb 19, 2018 8:35 pm Post subject: |
Eezibleeds?
How much pressure was being used?
I have found 3 or 4 lbs/sq inch enough to bleed a Skoda with 4 pot calipers...from a spare wheel.
Having a helper is not always a good idea....got my last ex-wife [need you ask??] to do that....spent ages wondering why no fluid was coming through.....finally noticed the clutch cable moving........! |
Posted: Mon Feb 19, 2018 8:52 pm Post subject: |
This afternoon I took off the rear light and GB plate followed by the supporting bracket. The assembly had become slightly bent when I reversed into something and has been bugging me for a while. Fortunately, I was able to acquire another square blank number plate in black (12" x 8.5"). The oval GB plate is a rare large old type and looks great mounted on the square plate so it is nicely in balance with the square number plate on the other side. I have used dome headed nuts to finish it off. The only difficulty was getting to the bracket bolts on the chassis cross member.
Recently I have been playing with paint on the front of the ignition switch. I have changed it from black to white with black lettering. It's more difficult than it would seem. |
BigJohn
Posted: Tue Feb 20, 2018 8:10 pm Post subject: |
Got to know my new toy, I needed an auto that my wife would drive as she finds the Escort too lairy, so I now have a 1993 Mk1 Golf Cabriolet auto in the garage. Strange having a classic, some might say it's too new for that title, I have to tax. |
Posted: Wed Feb 21, 2018 12:04 pm Post subject: |
Swapped the nearside top suspension bushes. Found that a reasonably big part of one of them had come away, which won't be helping the handling. It's really close to the exhaust manifold, so now I need to have a look at the engine mounting in case that has sagged. Other than that, really easy job to do as I made a point of putting some grease along the top bolt when it went back on in 1997. |
Kleftiwallah
Posted: Wed Feb 21, 2018 2:03 pm Post subject: |
I'm in the proccess of fitting the steering column brace. Whilst in training (one of Trenchards Brats) we had what was humerously called "Murder boxes". An ally box with access only at each end about 3" long and inside were various turnbuckles and wire lockable teasers. Without sight and only working by feel we had to wirelock the various turnbuckles etc.
Very much like that, with one hand in from the engine compartment and the other from the "Cockpit" it's a bit of a struggle. But then, if it was easy there would be no sense of achievment would there?? ?
Cheers, Tony. _________________ It may work in practice, but not necessarily in theory! |
Posted: Fri Feb 23, 2018 7:50 pm Post subject: |
Swapped the engine mounting that I referred to earlier. It had sagged quite significantly, and wasn't far away from the rubber separating from the metal on one side. |
Posted: Sat Feb 24, 2018 11:17 am Post subject: |
Regarding engine mounts. On the Jensen Owners Club forum there were two posts about this recently. One was that someone renewed the mountings with a new type, and as a result got his bonnet dented.
The other post is about the horror of modern dynamics....
Quote: | When I decided to ship my Bentley back from the UK I got it checked out bumper to bumper for any potential issues.
The one engine mount has an error reading? Huh - aren't they just blocks of rubber?
Not any more - they are connected to the ECU and depending what the engine is doing and the road speed the ECU tells the mounts to go soft or hard or somewhere inbetween. And guess what - they have to be replaced in pairs - only GBP350 each plus fitting! But it does have a lovely quiet idle! |
_________________ a car stops being fun when it becomes an investment |
Posted: Sun Feb 25, 2018 11:42 am Post subject: |
I finally (after about six months) looked into the Chrysler's engine missing under load at about 55 km/hour (30+ mph). It turned out to be an incorrect float height. I changed the float chamber top, float and needle and now things are fine. She was shutting fuel off a fraction too early in the float chamber and consequently starving the engine when I put my foot down.
Keith. _________________ 1926 Chrysler 60 tourer
1950 Austin A40 tourer
1999 BMW Z3
Posted: Sun Feb 25, 2018 7:32 pm Post subject: |
badhuis wrote: | Regarding engine mounts. On the Jensen Owners Club forum there were two posts about this recently. One was that someone renewed the mountings with a new type, and as a result got his bonnet dented.
Progress eh!!?!?!??!?
I spent the afternoon "running up" the old grey Fergie tractor, and giving it a comprehensive clean in the sun. Very pleasant, and not an ECU in sight
Posted: Sun Feb 25, 2018 7:33 pm Post subject: |
Took mine out for a quick run today, in the nice sunshine. It was getting low on fuel so I added a bit, and the drive seems to have done it good. I've now removed the heater box, as I've been intending to swap the heater matrix for some time. Every time I put the heat on, the windows steam up, indicating a bit of damp somewhere, so it's high time it got fixed. |
Posted: Sun Feb 25, 2018 7:56 pm Post subject: |
Put a much lower pressure on the Eezibleed, this worked.
The Jaguar 420 has two brake reservoirs, one for the rear and one for the front brakes. They have a cap which contains a float which turns on a switch when the fluid level is low. The switches worked but the corks do not float anymore. I opened up one and replaced it with a wine bottle cork I just had opened yesterday evening. Tested and it works now. The other one has to wait a few days
Replaced the electric column switch which put earth to the reverse light when the selector is at R, and 12V to the starter motor relay when in P or N.
Well, that's what it should do. The switch was broken and I took it out months ago, temporarily connecting the starter motor wires together (so that it would start regardless of the selection handle).
Opened the switch, a good old mechanical Lucas switch to find out the plastic lever was broken. Tried to repair it using superglue but it broke off again. Fifties and sixties car parts: it usually is the "new" material (plastic) which breaks/giveup after years. Finally after weeks I found another second hand switch for reasonable money - it came form the USA. New ones are available but for stupid money (> 150 UKP)
Opened this one up as well and the plastic lever is a little different but still good. However on the backplate the copper part for the reverse light was worn away - this means it will not switch the reverse light. The hinge pin for the lever is mounted too fragile for me to try to replace from the other switch - I could end up with two non-working switches. So I now have a part-working switch - only for the starter motor. I can live with that but would have preferred a better switch of course (am still looking).
Next problem is I lost the little pin that goes from the switch lever to the lever on the selector. This is simple to make, however I have to try to see what the exact length is needed. The adjustment is pretty awful to do as there is so little room under the dashboard. So, only half finished for now _________________ a car stops being fun when it becomes an investment |
Joined: 30 Apr 2013 Posts: 3805 Location: The Somerset Levels
Posted: Sun Feb 25, 2018 8:05 pm Post subject: |
I spent a couple of hours making rear wing stay templates for my Commer. I am fabricating the templates from Aluminium as its easier to bend cold. _________________ Various Rootes Vehicles. |
consul 57
Posted: Sun Feb 25, 2018 9:48 pm Post subject: |
replaced the speedo consol and added the missing window trim join covers on my mk2 57 consul highline.
a much neater job than the broken and badly repaired old one! |
Posted: Sun Feb 25, 2018 10:22 pm Post subject: |
I finally got the exhaust system finished on my old Jag. I got wind of a guy in the JDC who had 4 x NOS silencers for sale. That was the easy bit. Figuring out where and how it was mounted was another voyage of discovery but thanks to the patient help and photos from Peter Scott it now has a factory exhaust.
All I had before was the remains of two front pipes which I welded into a Siamese pipe. You'll love this next bit. My wife's BMW Mini had failed its first MOT at five years old but only was only because the outer casing was rusted through. I kept this and made a matching flange to fit to the front pipe. And Bob's yer father's brother, a makeshift exhaust system so that i could drive/move the car around without alarming the neighbours.
Art |
-> Classic & Vintage Cars, Lorries, Vans, Motorcycles etc - General Chat |
All times are GMT + 1 Hour Goto page Previous 1, 2, 3, 4, 5, 6 ... 119, 120, 121 Next
Page 5 of 121 |
