Rusty
Joined: 10 Feb 2009 Posts: 204 Location: Bunbury, Western Australia
Posted: Sun May 20, 2018 2:04 am Post subject: |
alastairq wrote: |
Ford {USA] had a problem with their products in the 1960's...with leaks. |
Ford in the US also had a "known" problem with their parking mechanisms in some of their automatic transmissions. If the vehicle was left in park with the engine running for an extended period, say 3 to 5 minutes the parking lever would be moved by the parking paul slowly working out of mesh, and guess what, when it moved far enough to disengage it also put the car into reverse and off it would go. I know of one instance in South Australia where an owner was killed by being squashed between the back of the car and the shed wall when this happened, and my own nephew was almost seriously injured when my family's 1965 Lincoln did it to him but luckily he gave up trying to stop it and let it hyper extend the door as it backed itself into the overhead fuel tank on the farm.
The thing with this is that Ford took the usual approach at the time and totally ignored the problem which would have cost a small fortune to put right, even knowing there was a serious problem, and nowadays I think the only reason that car company's are being seen to be more diligent is because of the litigation consequences if it is proven they knew of a problem and did nothing to rectify it.
I was surprised to hear Fiat in relatively modern times let a "known" failure of the brake system slide without fixing it. |
