Posted: Wed Jul 25, 2018 3:24 pm Post subject: |
I once fitted a high compression cylinder head to an Austin Seven engine expecting an improvement in the abysmal performance. Unfortunately, all it did was make the big ends knock. I retarded the ignition but that just put the performance back to what it was before and so I refitted the original head.
On the same engine I tried to open up the inlet manifold only to suffer a flat spot. I read that the the cam followers could be flattened to good effect but it made no difference. Several other modifications seemed to make no difference so I gave up trying to polish a turd (to use a political expression).
The mods that did make a difference were 1) altering the fulcrum point on the clutch levers to improve on the normally short travel and 2) utilising one of the front shock absorber arms in place of a vertical link to locate the front axle - and eliminate steering wander. |
Posted: Wed Jul 25, 2018 8:03 pm Post subject: |
When I was 17 (was I ever 17?) I had a mini 850.
I bought a 1300gt manifold and twin carb set up (why didn’t I buy the bleeding engine too!) and fitted it, together with the lovely leather steering wheel.
Made no actual difference to the performance other than using a lot more fuel 😁
Kev |
BigJohn
Posted: Wed Jul 25, 2018 9:33 pm Post subject: |
I had a Bedford Beagle (Viva HA Estate) 1156cc which I broke the engine on, I visited my local scrapyard on Saturday morning after driving to work for a week with mayonnaise for oil. I acquired a Viva engine with a 4 branch manifold, a Stromberg like a bucket, and a remote servo, £20, happy days! I fitted it all that afternoon. I then discovered it wouldn't start, foot flat on the throttle nothing, then thinking it might have flooded I took my foot of the throttle, it fired and screamed its head off. The throttle linkage was the wrong way round. It was a right sod to drive to the village pub that night, I needed 3 feet, one for the brake, one for the clutch, and one to shut off the throttle. I walked home and collected the car on Sunday morning. a new linkage was soon made up in the workshop for Monday mornings drive to work. (It went like the clappers, so not actually a failure) |
Posted: Wed Jul 25, 2018 11:08 pm Post subject: |
kevin2306 wrote: | When I was 17 (was I ever 17?) I had a mini 850.
Kev | At about the same age with exactly the same car and engine I did something more stupid...
I was driving from home; Chester to my Gran's; Uckfield Sussex in 1980 with my 17 year old 850 cc Mini 7 . Even though the car had been reliable, I decided that for such a long trip I would have to fit a triple gauge cluster that included a temperature gauge. For some reason I thought that it would be ok to drill a hole in the top rubber hose to fit the temperature sensor! Need less to say we (me and my girlfriend) did about 5 miles before we lost coolant! However in those days many petrol stations stocked hoses so we pulled in to one and I changed the hose.
The rest of the journey was uneventful, apart from getting a puncture and changing the wheel outside the Bank of England in London (this was pre M25 day's)
The return journey was really boring with not a single stop for anything!
viteran
Joined: 02 Dec 2016 Posts: 11 Location: South yorkshire
Posted: Thu Jul 26, 2018 3:12 pm Post subject: |
I also acquired an HA viva as a student in Glasgow.when the clutch cable snapped I had the bright idea of running a cord from the clutch around the wing mirror so I could operate it out of the drivers window.
Initiallly it worked butI forgot Vauxhall’s rust and the wing mirror collapsed into the wing. Incidentally it was green and you had to be careful where you parked it if Rangers were playing!
Ian |
Miken
Posted: Wed Aug 01, 2018 10:13 am Post subject: |
When I got my first motorbike at age 17 ( a 1976 Suzuki 125) someone at work informed me that if you warm up the petrol before it gets to the carburetor it makes your bike go much faster!
This sounded so obvious to me that when I got home
that evening I cut the rubber hose that connected the fuel tap to the carb and inserted a length of copper tube. I routed the pipe so it went between the fins of the cylinder head before rejoining the rubber hose at the carb end ("Why don't the manufacturers do this? " I was thinking).
Later I sped round to my mates house to show him my handiwork. The first thing he said was " why is there petrol p#$%ing out of your carb overflow? "
Clearly it had affected something in the float bowl so l quickly bodged it back to how it was before and then rode home
So, does hot petrol make your bike to faster?
What do you think! (This is a rhetorical question by the way).
Posted: Wed Aug 01, 2018 10:24 am Post subject: |
Miken wrote: | When I got my first motorbike at age 17 ( a 1976 Suzuki 125) someone at work informed me that if you warm up the petrol before it gets to the carburetor it makes your bike go much faster!
that evening I cut the rubber hose that connected the fuel tap to the carb and inserted a length of copper tube. I routed the pipe so it went between the fins of the cylinder head before rejoining the rubber hose at the carb end.
Clearly it had affected something in the float bowl so l quickly bodged it back to how it was before and then road home
What do you think! (This is a rhetorical question by the way). |
There was a time when it was believed that pre heating the mixture was a good idea. On my Dodge, for example, the air intake is directly over the exhaust manifold on the off side and warm air passes between the two middle cylinders to the inlet manifold on the near side. It was only later that it was realised that it is better to actually cool the mixture, thereby increasing it's density and the result was the intercooler. The only benefit I can see with warming would be to help with cold starting in winter.
That is my take on it but I am happy to be corrected if in error. |
Posted: Wed Aug 01, 2018 11:13 am Post subject: |
I guess it's a compromise. You want to heat the mixture in a cold engine to improve vapourisation but you also want to cool the mixture in a hot engine to get the maximum volume of oxygen.
JonV2
Joined: 02 Jan 2010 Posts: 38 Location: Melbourne Australia
Posted: Wed Aug 01, 2018 11:31 am Post subject: |
When I turned 18, my parents bought me an old Triumph 2000 Mk!, which was positive earth. I also spent my savings on a new car radio/cassette player but only realised after buying that it was negative earth.
I built a wooden cradle to insulate the radio from the body and even insulated the aerial mount. I ran heavy duty power cables directly from the battery terminals to the radio.
It turns out I wasn't as good an automotive carpenter as I thought I was; the first pot hole I hit the radio bounced out of the cradle and jammed against the gearstick. It shorted out, and started smoking. Before I could pull over it burst into flames.
1 x dead radio
Burnt plastic smell for 6 months
a 'weld' mark on the gearstick. _________________ Jon
1950 MkV Jaguar Saloon (On the Road)
1968 MGB
1959 XK150 |
Posted: Wed Aug 01, 2018 11:52 am Post subject: |
peter scott wrote: | I guess it's a compromise. You want to heat the mixture in a cold engine to improve vapourisation but you also want to cool the mixture in a hot engine to get the maximum volume of oxygen.
Peter |
Warming the intake air also helps prevent carb icing in cold/damp conditions, a lesson i learnt on my Volvo 340 when the flexible pipe from the exhaust pipe to the intake fell off without being noticed.
I called out recovery once to a dead engine and embarrassingly it started when he got there.
I didn't realise what was happening even though I was aware of the reason for carb heat from my flying lessons. I just didn't know it could happen at relatively low ground levels.
It was another recovery driver who worked around the Lake District who finally tipped me off about the cause. _________________ Bristols should always come in pairs.
emmerson
Posted: Thu Aug 02, 2018 7:10 pm Post subject: |
I fitted a heater motor on top of the carburettor on an A40 Devon to act as a "turbo" All it did was restrict the air flow and in crease petrol consumption.
I also fitted a piece of cardboard to strike the spokes on my bike! It sounded just like a piece of cardboard striking the spokes, but I thought it was great! |
Posted: Thu Aug 02, 2018 7:31 pm Post subject: |
When I was at college (hall of residence) some of the lads thought it funny to change the wheels of my A30 over for mini wheels. I couldn't find my wheels so had to go into college like it. The car handled very oddly but worst was trying to get over road humps. The exhaust was damaged but not badly. Fortunately when I got back my wheels were stacked up ready.
I tried to see the funny side but in truth I was not amused. |
BigJohn
emmerson wrote: |
How many parents in the 60's discovered they were missing a (some) playing cards and a few pegs? But most of my friends and I were a few cards short of a full deck anyway.... |
Ellis
Joined: 07 Mar 2011 Posts: 1382 Location: Betws y Coed, North Wales
Posted: Sat Aug 11, 2018 7:48 pm Post subject: |
I can relate you a true story of a young Land Rover enthusiast in this area.
Car mechanics and Land Rovers are part of his and his family's DNA and about three years ago he decided to create the ultimate trialling machine.
He had a Land Rover 1952 Series One 80" "in stock" and he turned his attention to that.
He grafted on Series 2 88" sports parabolic springs, pro comp dampers, a highly tuned ex Discovery 200TDi engine with a huge intercooler.
He added ex Range Rover 3.54 diffs, Series 2 front swivels and more. The whole task took months of his skills and a great deal of money. On testing it drove magnificently and he looked forward to entering local trials.
He was disqualified from his first event, and the second and the third............
Other competitors complained about the extensive modifications and the scrutineers agreed.
Disullusioned, he rebuilt the 80" Land Rover on a modified ex Discovery chassis and was then eligible to enter the "Special" classes of competition.
One day, he knocked on my door and asked if I would be interested in buying his erstwhile "illegal" chassis as a donor suspension component source for mine. I politely refused at first but three weeks later we agreed a paltry price and he delivered the chassis to me on a trailer.
It will all go on my '62 2a.
Modifications that go wrong and some............... _________________ Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet |
