Posted: Sun Apr 07, 2019 9:46 pm Post subject: Ford E93a con rods |
I have been having a bit of a tidy in the garage and came across a box of 7x new old stock Ford E93a con rods that I had forgotten about. They are labelled as refurbished, individually wrapped in protective paper and each is boxed in FOMOCO packets and packed in a FOMOCO box. The internal white metal bearings measure 1.5".
I don't know how scarce these parts are or if needed but I would be happy to let them go to a new home for a reasonable consideration. |
Mog
Posted: Tue Apr 09, 2019 6:37 am Post subject: |
Perhaps a donation of a few cases of beer ? I met a couple in a caravan park, in N.W . Q'land . They were living in a converted double decker bus . There was a stack of about 10 cases of beer , that raised my eyebrows . I did not ask if he had bought them or were a donation for work done .... BTW if you use a bus on the open road you need to change the ratio in the rear diff .
Bus - that has been used in the city on a low ratio . |
