Mystery Car
jesscarter1
PostPosted: Thu May 09, 2019 12:25 pm    Post subject: Mystery Car Reply with quote
Hello,
I'm hoping someone can help me identify a car. I'm afraid the photograph doesn't show all of the vehicle which does make this mystery a little hard. My current thinking is that it might be an Austin A30 or A40 but please feel free to correct me. For reference, this photograph was taken in Essex in 1958.
Jess
[/code]
Code:
PostPosted: Thu May 09, 2019 1:16 pm    Post subject: Reply with quote
Austin A30 [A35?] Countryman?
jesscarter1
PostPosted: Thu May 09, 2019 1:23 pm    Post subject: Reply with quote
alastairq it does look awfully like the car in this photo: https://www.flickr.com/photos/42220226@N07/32105562185
The door panel was previously confusing me so this is great. Thank you.
PostPosted: Thu May 09, 2019 3:37 pm    Post subject: Reply with quote
I donít think itís an A35 because that looks to me to be an external door hinge. Plus the A35 has that raised moulding running the length of the wing and through the side-lamp.
Art
PostPosted: Thu May 09, 2019 6:14 pm    Post subject: Reply with quote
Art
I think you will find that the A30 and the A35 both have the full length raised wing beading and exterior door hinges so it could be either.
PostPosted: Thu May 09, 2019 6:39 pm    Post subject: Reply with quote
Ray,
My point was that I donít see the raised moulding. Do you? The picture of the A35 doesnít show an external hinge.
Art
PostPosted: Thu May 09, 2019 6:45 pm    Post subject: Reply with quote
47Jag wrote:
Ray,
Art
Yes, I made out the raised moulding - which is in fact plastic piping between the edge of the wing and the bonnet surround. The top of the exposed door hinge is also visible.
PostPosted: Thu May 09, 2019 6:59 pm    Post subject: Reply with quote
Seems the A35 also has exposed hinges...with vans & Countrypersons having inset door panels as well? Same as A30?
PostPosted: Thu May 09, 2019 7:06 pm    Post subject: Reply with quote
It depends. Later vans did not have recessed door panels in the doors - although they retained them in the rear quarters.
https://www.carandclassic.co.uk/car/C911221
PostPosted: Thu May 09, 2019 8:27 pm    Post subject: Reply with quote
Ray,
Art
PostPosted: Thu May 09, 2019 8:34 pm    Post subject: Reply with quote
47Jag wrote:
Ray,
Art
If what you mean by "raised moulding" is the piping which extends the whole length of the wing top (including through the side light) then yes I can identify it from the mystery photo. All A30s and A35s had external door hinges and part of the n/s front door hinge is also visible in the mystery photo.
PostPosted: Thu May 09, 2019 9:24 pm    Post subject: Reply with quote
I suspect that the "raised moulding" referred to might be in respect of the linked flickr pic which shows that the "wood" panel is actually in a recessed panel on the door giving the impression of a raised moulding surrounding the "wood".
This is not obvious in the B/W pic
The driver appears to be Nigel Green so I think this is a still from either a film or TV prog/
Do any of these shown in his filmograhy ring bells
https://en.wikipedia.org/wiki/Nigel_Green
jesscarter1
PostPosted: Thu May 09, 2019 10:06 pm    Post subject: Reply with quote
I'm afraid the driver isn't Nigel Green. He's a normal citizen.
jesscarter1
PostPosted: Thu May 09, 2019 10:35 pm    Post subject: Reply with quote
Thanks to everyone who has chipped in so far. Am I to take it that it is at least an Austin, even if it isn't 100% definitely the A30/35 Countryman?
PostPosted: Thu May 09, 2019 10:40 pm    Post subject: Reply with quote
I would say that if the car is an Austin it would have to be some kind of A30/A35. If not then further identification might not be possible.
