Hydrogen, batteries and *The Future*
PostPosted: Sun Jun 02, 2019 11:13 am    Post subject: Reply with quote
Quote:
and making sure there are no naked flames about.
Or, naked 'old' flames...for that matter... Smile Smile
DM
PostPosted: Sun Jun 02, 2019 11:35 am    Post subject: Reply with quote
Minxy wrote:
The electric car we are considering can be fast charged in 45 minutes at 50kW.
Is your house supply capable of supplying 50Kw ?
A normal household single phase supply is usually 16.5Kw.
Minxy
PostPosted: Sun Jun 02, 2019 12:17 pm    Post subject: Reply with quote
Fast chargers are the ones you see in car parks and service stations, at home you charge at about 7kW the idea being you can charge, if necessary, overnight to 100% this will, depending on the car, take you circa 200 mile ( a lot more with a new vehicle) If you are doing a greater mileage you top up at a fast charger if you are in a hurry, or something less aggressive if you have time.
Miken
PostPosted: Sun Jun 02, 2019 1:21 pm    Post subject: Reply with quote
47Jag wrote:
I personally canít see the attraction of converting a classic car to electric. I mean, what our hobby is all about is keeping ancient machines running, against all odds at some times.
Art
Art, I'm sure you are correct and in the majority.
Not looking very hopeful for the survival of old cars, is it.
Mike
PostPosted: Sun Jun 02, 2019 4:03 pm    Post subject: Reply with quote
In daylight, when the weather is such that you don't need wipers, heater or air-con. preferably in a country which doesn't require daylight running lamps.
Try night time, torrential rain/heavy snow/fog etc.
Then how far will it go?
Minxy
PostPosted: Sun Jun 02, 2019 5:17 pm    Post subject: Reply with quote
Er.......a bit less, itís an electric car! Canít remember the last time I drove at night with all four seasons being thrown at me though. Smile
Interestingly the countries with the greatest uptake of electric cars are some of the coldest
Miken
PostPosted: Sun Jun 02, 2019 6:02 pm    Post subject: Reply with quote
[quote="Minxy"]
Interestingly the countries with the greatest uptake of electric cars are some of the coldest[/quote
Don't EV,s have a separate dedicated battery for running the lights, wipers etc?
Minxy
PostPosted: Sun Jun 02, 2019 6:11 pm    Post subject: Reply with quote
[quote="Miken"]
They do still have a Ďregularí battery under the bonnet yes to power the 12 volt system but on a long trip in cold adverse weather Penman is quite correct that range would be reduced.
DM
PostPosted: Sun Jun 02, 2019 6:18 pm    Post subject: Reply with quote
Looks like a 20% decrease in range due to cold weather.
https://www.wired.com/story/electric-cars-cold-weather-tips/
Minxy
PostPosted: Sun Jun 02, 2019 7:05 pm    Post subject: Reply with quote
I believe some are better than others it depends on whether they have active battery management ( heaters to warm them when cold, coolant to cool them when hot) or passive management( heat sink from ambient air around the battery). Some can be as high as 30%. This compares with around 12% on an internal combustion engine ( yes it even affects your conventional car)
Miken
PostPosted: Sun Jun 02, 2019 8:26 pm    Post subject: Reply with quote
How
That's a good point Minxy. I ran a diesel Berlingo for 9 years. On the drive to work in the summer it would do 55mpg. In the winter about 50. It also took about 3 miles to get up to temperature during which I didn't run the heater or it took even longer.
Rusty
PostPosted: Mon Jun 03, 2019 2:14 am    Post subject: Reply with quote
I "shudder" every time I see prince Harry on the TV driving his electric E type, it just misses the point ! Out here we have a chap who does electric conversions on all sorts of vehicles and he drives (or used to, don't know if he still has it) a mid 60s electric Ford Mustang, and I am sorry, but hearing it glide silently past is just "Wrong".
Minxy
PostPosted: Mon Jun 03, 2019 8:44 am    Post subject: Reply with quote
I agree 100%......but in x amount of years time would you rather see that mustang glide past silently or not see it at all?
Minxy
PostPosted: Mon Jun 03, 2019 8:57 am    Post subject: Reply with quote
Back to the OPís question.
It doesnít take long on good old google to come up with companies that supply all the basic generic ingredients to convert a vehicle, motors, battery packs, chargers etc etc. There is no separate gearbox with an electric motor just a single speed forward and back Ďcogí so the output coupling just needs connecting to your prop shaft. Hydrogen could also be employed but would obviously need all the extra hardware that this encompasses on top. From an engineering perspective it would first appear to be relatively strait forward.
alanb
PostPosted: Mon Jun 03, 2019 4:40 pm    Post subject: Reply with quote
Whatever type of battery used you can't get out more than you put in, so where is all this electricity going to come from? We don't generate enough for our needs now, we have to buy additional supplies in from France and maybe the French won't sell it to us after brexit
old tourer
Morris 8 two seater
Page 3 of 4
