New Austin 10 owner.....
MattF
PostPosted: Tue Jun 04, 2019 8:13 am    Post subject: New Austin 10 owner..... Reply with quote
Hi everyone Iím an old member of old classic however this is my first post on this forum. Iíve had a morris eight for the last 10 years but a couple of months ago she was joined by an Austin 10. This car is in less than perfect condition... as in the previous owner has started a resto 😳😱
Anyway get ready for a bunch of questions because the only thing I recognise is the SU carb and I realise thatís not original.
So for my first question - has anyone taken apart an Austin fuel pump? The owners manual says not to because a ďspecial fixtureĒ is needed to put it back together?
Ps: Iíll try work out how to pop photos up later, Iím sure I remember there being instructions on gear somewhere.
PostPosted: Tue Jun 04, 2019 1:59 pm    Post subject: Reply with quote
Look forward to reading more about the Austin. Try imgur.com for hosting images, it works pretty well and I use it with another (non-car) forum.
Rick (OCC Admin)
MattF
PostPosted: Wed Jun 05, 2019 8:22 am    Post subject: Reply with quote
https://i.imgur.com/driPG51.jpg
https://i.imgur.com/vws9lYv.jpg
https://i.imgur.com/N8vZ0H3.jpg
https://i.imgur.com/h4bIGW2.jpg
https://i.imgur.com/82AKNsV.jpg
MattF
PostPosted: Wed Jun 05, 2019 8:27 am    Post subject: Reply with quote
Not sure if Iím doing something wrong or is it not possible to see the photos?
PostPosted: Wed Jun 05, 2019 8:41 am    Post subject: Reply with quote
Any better? Smile
MattF
PostPosted: Wed Jun 05, 2019 8:50 am    Post subject: Reply with quote
So how did you manage to make it work??
PostPosted: Wed Jun 05, 2019 9:01 am    Post subject: Reply with quote
I learnt to drive in a '34 wide body version.
If you don't already have a book, you could do with getting one of these.
https://www.abebooks.co.uk/servlet/SearchResults?sts=t&cm_sp=SearchF-_-home-_-Results&an=&tn=book+of+the+Austin+Ten&kn=&isbn=
My father and I did some quite involved mechanical jobs using one of them as our reference.
Should be side-draught Zenith carb.
MattF
PostPosted: Wed Jun 05, 2019 9:06 am    Post subject: Reply with quote
Thanks penman. Which ones do you recommend? I feel like I have one by Abbey for the morris eight that is quite good. Unfortunately Iím not old enough to be able to say I learnt to drive in anything as cool - Toyota coldina is NOT a cool car!!
PostPosted: Wed Jun 05, 2019 10:44 am    Post subject: Reply with quote
I'd go for the Pitmans, Abbey book.
What I don't know is whether the ones covering the later dates as well as the earlier ones have reduced coverage on those earlier ones or have just got thicker..
These people might be able to help about that though.
https://www.austintendriversclub.com/
PostPosted: Wed Jun 05, 2019 11:43 am    Post subject: Reply with quote
Very nice, I had a 10/4 cabrio project many years ago.
To get the images to show, just paste in the links you have in between the img tags, using the Img button just above the little window where you enter the text of your posts into.
Rick (OCC Admin)
MattF
PostPosted: Wed Jun 05, 2019 11:51 am    Post subject: Reply with quote
Like this?
PostPosted: Wed Jun 05, 2019 12:04 pm    Post subject: Reply with quote
Looking at the H/Lamps, it looks as if it still has the switch and dip system rather than double dip.
MattF
PostPosted: Thu Jun 06, 2019 8:30 am    Post subject: Reply with quote
Couple photos of the dash
[/img]
MattF
PostPosted: Thu Jun 06, 2019 11:06 am    Post subject: Reply with quote
The rest of the interior:
Anyone know if this roof light is original?
Looks like a dimmer foot pedal? Iíve seen them in other cars but never used one...
As you can see the wall lining seems in ok condition however sets and roof are a mess. Was it normal for the lining to be the same colour (green) as the exterior and the seats to be brown?
PostPosted: Thu Jun 06, 2019 11:18 am    Post subject: Reply with quote
Yes, that is the dip switch.
Personally, if we only had dip these days I would rather have it down there than the stalk type; but of course we now have the flash function as well which would be more difficult to include.
