Self Drive car transporter.
PostPosted: Fri Jun 07, 2019 4:39 pm    Post subject: Self Drive car transporter. Reply with quote
Has anyone hired one of these?
I recently hired a self drive car transporter for the day to collect my newly purchased MG TC from Lyndon, nr. Oakham in Rutland. I picked up the Transporter from Nottingham and collected the car without issues. I had never used this type of transport before as I had always borrowed a trailer and towed it behind the Range Rover. For 100 a day I must say it was a breeze. A most enjoyable stress free way of transporting a car. There is an electric winch if needed and wheel straps are provided.
Highly recommended.
PostPosted: Fri Jun 07, 2019 5:09 pm    Post subject: Reply with quote
That is indeed excellent but I mustn't tell my friend who is addicted to buying cars.
Peter Very Happy
1939 SS Jaguar 2 litre saloon
PostPosted: Fri Jun 07, 2019 5:48 pm    Post subject: Reply with quote
We have hired a 7.5 ton beavertail to use on Monday as we have to move some vehicles. Its 150 per day and the 3.5 ton beavertail is 100, even adding our fuel use on top its much cheaper than paying a 3rd party.
1937 Ford 7w
1946 ERF C.I.5
1947 Hillman Minx
1955 Hillman Minx Mk8
1950 Commer R541
1978 Karrier Bantam
PostPosted: Fri Jun 07, 2019 6:35 pm    Post subject: Reply with quote
That does sound like a good option, though I have to say I would have probably been looking to simply drive the new oldie home under its own power over such a distance... or does it need some work doing?
PostPosted: Fri Jun 07, 2019 6:59 pm    Post subject: Reply with quote
The advantage of a self drive transporter is that you can do the job of collecting the car by yourself, at a time to suit you - otherwise you need to rely on someone to drive you there or drive your car back.
As it happens, the tyres date from the 1960s and the brakes require attention. How clean is the fuel system for example.? The p/o had not driven the car since rebuilding it so reliability is an unknown quantity.
I intend to go through the car in detail to satisfy myself that it is safe and reliable before taking to the road.
When I do get the MG on the road I will be the first person to drive TC 1030 since the 1960s!!
PostPosted: Fri Jun 07, 2019 8:25 pm    Post subject: Reply with quote
That looks a much better bet than the kit of parts you were looking at.
PostPosted: Fri Jun 07, 2019 9:19 pm    Post subject: Reply with quote
Yes Mike. I had been drawn to the many expensive new parts including the powder coated chassis which had been checked for alignment and the replacement Ash frame...but I calculated that there was at least 1000 hours needed to reassemble the bits and there was no guarantee that it was all there.
You were right; at half the price it would still not be cheap. This way I can soon have the car on the road and improve on it to a higher standard.
I was just 13 years old when an acquaintance of my Dad turned up in an immaculate Red MG TC with light tan interior ...and I decided there and then that one day I would have one. Now, half a century later, I have a car like the one that so inspired that young lad.
PostPosted: Fri Jun 07, 2019 10:30 pm    Post subject: Reply with quote
I have started a separate thread for the MG.
I hope it will be an interesting journey.
It would be helpful to chat with any other TC owners especially for the finer details.
old iron
PostPosted: Sat Jun 08, 2019 3:40 pm    Post subject: Reply with quote
Yes I have hired transporters on a number of occasions. Just make sure that the vehicle you are collecting is not going to exceed the weight amity of the transporter. Sounds obvious I know but some pre war cars are deceiving in weight.
PostPosted: Sat Jun 08, 2019 4:01 pm    Post subject: Reply with quote
Agreed, always check the weight and length limits of the carrying vehicle. Its a simple mistake that I have known happen.
1937 Ford 7w
1946 ERF C.I.5
1947 Hillman Minx
1950 Commer R541
1978 Karrier Bantam
PostPosted: Sat Jun 08, 2019 4:39 pm    Post subject: Reply with quote
Would also suggest you make sure you have 4 straps bone for each wheel, I despair, when out in the one from work, the number of times I see them with only 2 in use (1 front and the other diagonally at the rear).
If the pressure down on the tyre should cause an over pressure blowout then they are left with only one holding the load.
This could be even more important with old tyres like the MG.
PostPosted: Sat Jun 08, 2019 5:09 pm    Post subject: Reply with quote
Beaver tails are excellent for getting cars!
When my brother bought a Rover P5B back in the nineties we would never had gotten it out of its very narrow resting place if there was not an electric winch.
PostPosted: Sat Jun 08, 2019 5:21 pm    Post subject: Reply with quote
The one I hired had a winch but fortunately I didn't need it. The transporter is a Vauxhall 3.5 litre and to my surprise even had a 6 speed box!
I used to drive a Ford Transit 190 (long wheelbase with twin wheels) for a living and was not expecting electric windows and a comfy seat!
PostPosted: Tue Jun 11, 2019 10:53 am    Post subject: Reply with quote
We used a Mercedez Atego 7.5 ton beavertail yesterday, I drove it from Somerset up to Windsor to collect a car. Superb lorry, cruised along at 18-19mpg. Good strong winch that was brilliant to use as it was raining and it made it so easy.
1937 Ford 7w
1946 ERF C.I.5
1947 Hillman Minx
1950 Commer R541
1978 Karrier Bantam
PostPosted: Tue Jun 11, 2019 11:30 am    Post subject: Reply with quote
Weights are often overlooked...or simply presumed to be within the limits for the tow vehicle.....especially if that tow vehicle is a product of Solihull....or a fancy modern crew cab pickup truck from the far east.
Yet it amazed me how..effectively....little those vehicles are permitted to tow.
What is also often ignored is the train weight.
Ignored, because the load is sat on a trailer which is hitched up behind.......and lots of spares stuck in the back of the tow vehicle.
My old faithful for towing stuff is my daily Daihatsu Fourtrak...with its 5 3/4 tonne [as near as dammit] gross train weight..as per the weight plate in the engine bay. truly a farmer's friend..including the interior which smells of damp sheep...and a real multi-fuel engine! [I've tried, it is!]
I like the idea of hiring a beavertail..[but sadly out of my financial reach]...and even looked at a small old one for a daily runabout....[always fancied a bull-nose Mercedes].....
But, I [until recently] had a huge twin axle trailer..big enough to carry a Volvo estate...built by a Nottingham blacksmith back in the now-tax-free days....everything built in...darned thing....but, my Volvo 740 estate towed it..and even managed to stop it! Got rid recently...it was, for me, a liability too far.....[There is a house in Shropshire that had one of it's wheels in their front hedge...no idea where, it was dark & wet...and went unnoticed for quite some distance, until a toilet break, and a quick check, noticed something missing.....There was a spare wheel...but, unfortunately, not enough wheel studs left......Oi Oi, here we come! Yet another arrival home in the wee early hours...under amber flashing lights......the joys of trialling!!
