D.I.Y. Crack testing
PostPosted: Fri Aug 02, 2019 4:39 pm    Post subject: D.I.Y. Crack testing Reply with quote
This was my first venture into crack testing.
I have read numerous reports of spindle failure on MG TCs so with the hubs removed to replace the king pins and bushes I took the opportunity of crack testing them.
The kit consists of three cans. 1) a cleaner; 2) penetrant; 3) developer.
Following the instructions: (Wearing rubber gloves; a face mask and goggles.)
First I cleaned the part with particular attention to the underside radius area where the pin joins the upright.
Secondly I sprayed on the penetrant and left for at least 10 minutes.
Finally, I cleaned off the dye and applied the developer. Having left this to dry I inspected the suspect area.
temporary image hosting
In this case I found no sign of cracking - so that was a relief.
JohnDale
PostPosted: Sun Aug 18, 2019 5:43 pm    Post subject: Reply with quote
Hi Ray, didn't realise this stuff was still available. We used to use the same(or similar) on crankshafts in the late '50s. Brought back some memories, cheers,JD.
1976 Ford Granada Ghia.
Mog
PostPosted: Wed Aug 21, 2019 5:09 am    Post subject: Reply with quote
If you are checking for cracks on a cylinder head or block , you can fill it up with kerosene or paraffin . I am assuming that you have it dismantled . It will find its way out of a crack , maybe cheaper than getting an " expert " to do it !
Brent29
PostPosted: Fri Aug 23, 2019 2:23 am    Post subject: Reply with quote
That looks like a great stuff! Good relief indeed it was cleared for cracks.
PostPosted: Mon Aug 26, 2019 2:54 pm    Post subject: Reply with quote
I still have the other side to do yet!
These MGs were quite prone to spindle failure so fingers crossed!
Brent29
PostPosted: Tue Aug 27, 2019 3:43 am    Post subject: Reply with quote
Sending you more lucks for the other side crack testing.
PostPosted: Tue Aug 27, 2019 9:58 am    Post subject: Reply with quote
Thanks. I will post more about how I get on when I do the other side.
So I can be sure how things go back together I am restoring one side of the car at a time.
