Joined: 14 Oct 2016 Posts: 1952 Location: East Yorkshire
Posted: Mon Sep 23, 2019 10:20 am Post subject: |
Ray White wrote: | Excellent Alastair ...but how does it work?
(Please be patient with me) |
I suspect...the float slides up and down the track?
I linked that purely as an example....less 'Chinesey' items may be had elsewhere..but at a price.. _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Mon Sep 23, 2019 10:29 am Post subject: |
https://www.asap-supplies.com/fuel-systems/fuel-gauges-senders/level-senders
From gooogle, this page show a list of the sliding senders of various lengths....the MG's fuel tank will be quite a deep one...maybe at least 18 inches or more, perhaps?
Exactly how does the 'low fuel level' warning light actually work? Would it not receive its signal from a 'sender?'
Another issue with fitting a 'sender' is, getting a gauge to which the signals match. _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Mon Sep 23, 2019 10:32 am Post subject: |
alastairq wrote: | Ray White wrote: | Excellent Alastair ...but how does it work?
I linked that purely as an example....less 'Chinesey' items may be had elsewhere..but at a price.. |
The problem there is that the length of the track is only 200mm which assuming it is top mounted would not be long enough.
Here is the tank as found in Australia
Note the back of the tank has been opened up at some time...
Posted: Mon Sep 23, 2019 10:37 am Post subject: |
alastairq wrote: | https://www.asap-supplies.com/fuel-systems/fuel-gauges-senders/level-senders
Another issue with fitting a 'sender' is, getting a gauge to which the signals match. |
Yes, it would need to have a long reach.
The sender unit operates a simple switch and light. MG were able to get away with not even having a water temperature gauge...not even a Motometer on the rad!
I understand that cars were in great demand after the War so anything went.
A side view.
Posted: Mon Sep 23, 2019 11:10 am Post subject: |
alastairq wrote: | My Dellow has a 15 gallon fuel tank, stuck on the back like the MG's.
Dellows also didn't have a fuel gauge.
Aside from the fact that to fill the tank would be beyond my [pension-supported] means...I have a long piece of hardwood, about 1/2" square....and spent a happy morning sniffing petrol fumes whilst I drained the tank to stuttering point...then added one gallon after another, marking the fuel dipstick [literally..a stick!]......until my wallet cried ''enough''....
The marks were scorched in using one of those cheap cordless soldering irons [from Liddel]....
The stick lives behind seats ...[I must produce a purpose-made pair of clips for it.]
Wood is best, in my view, as the fuel level can be clearly seen on the [dark] wood...I did consider brass...but couldn't find any brass long enough to reach the tank bottom from the filler. Besides, petrol is harder to see on metal.
I might, one day, affix a posh handle to the top of the stick...but that day will be a long time coming [I don't 'do' external picnic baskets either]... |
I have a purpose made dip stick which I use on my Austin Seven Swallow. The tank sits under the bonnet and checking the petrol level is easy but then again I don't go far in it.
The MG will be a different kettle of fish. Building up a fairly common car from a desperate pile of bits one does not feel the same need to "re create" originality. If I can fit a proper petrol gauge then I don't see why I shouldn't. I will also have a water temperature gauge ...and a supercharger boost/vacuum gauge.... |
traction39
Posted: Mon Sep 23, 2019 11:27 am Post subject: |
I have to say that the wood stick works remarkably well!! _________________ Alistair
Riley 9 Special 1932 |
Posted: Mon Sep 23, 2019 12:51 pm Post subject: |
Ray
As long as the instrument builder is aware of the resistance range of the sender, they will be able to build a gauge to suit.
Posted: Mon Sep 23, 2019 1:25 pm Post subject: |
Hello Dave. Interesting possibility. Pity they don't do one 500 mm.
Also, what is VDO? please explain. |
Posted: Mon Sep 23, 2019 1:39 pm Post subject: |
There is another possible solution.
A sight glass.
2 ninety degree brass elbows, one let into the the tank near the bottom and the other one near the top and a glass tube connecting them. _________________ Bristols should always come in pairs.
Posted: Mon Sep 23, 2019 1:41 pm Post subject: |
VDO is a company that make lots of automotive electronic and electro-mechanical devices. You see their name on lots of instruments.
You could fit the 450mm unit and treat the bottom 50mm as your "reserve" tank?
Posted: Mon Sep 23, 2019 2:58 pm Post subject: |
ukdave2002 wrote: | VDO is a company that make lots of automotive electronic and electro-mechanical devices. You see their name on lots of instruments.
Thanks for that. Yes, I suppose I could still keep the low level warning light as well.
No excuse for running out then!!! |
Posted: Mon Sep 23, 2019 3:03 pm Post subject: |
Penman wrote: | Hi
A sight glass.
2 ninety degree brass elbows, one let into the the tank near the bottom and the other one near the top and a glass tube connecting them. |
Sight glasses [on a petrol tank] are quite vulnerable to damage from external means [a stone flicked up, for example?]
Not to mention an introduction to another method of leakage? _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Mon Sep 23, 2019 3:08 pm Post subject: |
Penman wrote: | Hi
A sight glass.
I have one of those on my oil central heating tank!!!
The idea with this MG is to have an old car without the limitations.
I may be reckless but this is my pension!! |
