1909 Alldays and Onions 2 seat Runabout
Goto page Previous  1, 2, 3 ... 24, 25, 26 ... 30, 31, 32  Next
Rdover
PostPosted: Fri Aug 01, 2014 9:51 am    Post subject: Reply with quote
Update from yesterday
AAAAARRRRRRGGGGH!
Just when I thought it was plain sailing, it appears that if I don't check on things every day nothing happens ....
So I called the engineering shop where the cylinder block is having a new valve seat installed and the guy says "Do you have the screw in thingy for the top of the engine?". Says I "you mean the valve cap?, of course, I've got loads why do you need it?". "Well," comes the reply, "I've ground out the old valve seat but it is now wider than the bore of the valve cap thread and I need to widen it by another few thou' to get the new valve seat in."
Bugger. I had to drive across Glasgow, through the Games area to collect a couple of valve caps (they are all slightly different), take them out to Stirlingshire for him to look at. That took 2 hours and all he did was screw them in and go "Aye, that'll be alright."
It should be ready by Wednesday and the engine will be half built by then as well. At that point the back cylinder block can be cleaned, painted ready to be installed on Friday, with only the manifolds, water collectors and bits before putting back into the car.
It looks like we're okay for testing in 10 days time and okay for 200 miles of driving on the weekend of the 16th. It being cut very fine indeed!
Richard
Rdover
PostPosted: Thu Aug 07, 2014 10:19 am    Post subject: Reply with quote
The excitement builds, as does the nervousness.
I collected the repaired rear cylinder block yesterday with Mike at Blane Precision Engineering finally admitting that he was worried he could fix it! The problem was having to bore the seat out to the point where the insert was wider than the bore of the valve cap it had to get through! Luckily there was more than enough thread for it to be shaved to allow the insert to be squeezed through. Phew!
The result is very nice
Before
after
And some photos of the crank and bearing carriers all with matching numbers (apart from a couple of wee errors from the 80s)
some photos of the repainted from cylinder and other parts
The guys rebuilding the engine have been doing a great job and Keith, the main guy, fully understands where I'm coming from when I say I want the engine cleaned rather than polished. In my opinion cars of that age which have been polished beyond all reason, to a point far removed from how they were at the time remove much of the history and patina as well. It means that when vehicle historians or those, like me, doing research into their own projects, do not have a genuine reference point for the layout and standard/quality of the original car. Of course I'm not referring to the art and effort of keeping Brass Age cars gleaming but the 'concourse' competitor who takes the time and effort to polish the jack or the rough aluminium casting. I appreciate the effort and the art involved by it is not to my taste.
Why do I make this point? I made it 100% clear that I wanted the engine cleaned, repainted where necessary but NOT polished. It is 102 years old and 50 or 60 of those years were spent being knocked around in a barn in South Africa. A car like that carries it's biffs and bashes and scars proudly. So .... Keith's assistant, the detailing guy, started to polish up all the copper pipe and water collectors and was only stopped when I came in and had a fit last week. I went in yesterday to find they'd cleaned the engine block and sump perfectly by steam cleaning but had done nothing else and then I spotted the side covers. These carry the maker's name behind the manifolds and apart from being manky with old oil they were otherwise perfect and only needed a serious degrease but this muppet had painted them silver!!!!
As calmly as I could, I told them to get the paint off them using chemicals and NOT mechanical means. For the 4th or 5th time I explained why I did not want my car turned into a over restored show piece. To say I am upset is an understatement and they had better not damage the covers when they remove the paint.
That aside, I should get the car back, running on Saturday afternoon.
Richard
PostPosted: Thu Aug 07, 2014 11:23 am    Post subject: Reply with quote
They'll think you are a hard man to please Richard, but I am with you completely!
Rdover
PostPosted: Thu Aug 07, 2014 12:18 pm    Post subject: Reply with quote
Not really, I gave them the easy option and explained it fully Rolling Eyes
Still, it will be fantastic and a minor bobble will not spoil the excitement
Richard
Rdover
PostPosted: Thu Aug 07, 2014 12:27 pm    Post subject: Reply with quote
Xpajun of Difflock wrote:
It's very upsetting when someone thinks their ideas are better than yours, and then act on it - very much proves the adage "if you want a job done properly, do it yourself"
Sure I'm upset but I do have a sense of proportion on the matter. Their main business is maintaining a wedding car fleet which are all white and black. Their boss, an old school classmate of mine, has loads of money but bugger all taste sometimes and 'restores' everything he can reach, including a car that was 50 years old, perfect in almost every way and really only needed some leather feed and a good service to be ready to show. He had it stripped and repainted!
This was a job that whilst well within my ability was far outwith my experience never mind not having the time and it needed Keith's 40 years experience with vintage Rolls Royces to properly strip, test and rebuild. It is clear that he is the man for the job and I know enough to see that. The engine will not need touched, barring a wee fettle here and there for a generation at least.
I will be fascinated to drive it again. It should be much quicker (not necessarily a good thing considering the lack of braking), much more frugal and easier to start which will make living with it more of a pleasure.
I'm anticipating cranking it to need more effort!
Richard
Rdover
PostPosted: Tue Aug 12, 2014 9:19 am    Post subject: Reply with quote
I went back to help finish fettle the car before picking it up yesterday afternoon and arrived to find it ticking over rather nicely. Keith had fixed a water leak, cleaned the idle jet and replaced the spark plugs and it now starts (hot or cold) like it should.
We went for a drive and on the flat, given enough time and space will get to 30mph. I still feel it is a little flat and either needs more advance or a richer compensating jet or both.
It now ticks over at about 450rpm, does not get nearly as hot and generally runs very nicely indeed.
I just need a dry evening to go for a tuning run before Saturday's big run ... and find all my notes which have been 'tidied up' by someone Evil or Very Mad
Tuning involves advancing the timing to the point that it almost tries to break your wrist as you start it and leaving that as maximum retardation. Then you can advance it at the wheel past the best point so you can feel what's happening.
At the moment it is not revving with alacrity (as the manual says) which mean the compensating jet needs opening up a touch to make more fuel available during acceleration. The plugs are a little black which means the main jet is about right.
I've been charging up the batteries (which were almost flat) overnight and will spend a hour or so fettling this evening.
I've already made all new hand throttle and ignition control rods and I'm lining up a whole host of winter jobs safe in the knowledge it is now a nice reliable runner Cool Cool
Richard
PostPosted: Tue Aug 12, 2014 5:41 pm    Post subject: Reply with quote
Hurrah, great news
Kev Very Happy
PostPosted: Tue Aug 12, 2014 8:59 pm    Post subject: Reply with quote
Great news and testament to your and the engineer's skill and organisation. I know you're going to have fun with that.
Rdover
PostPosted: Tue Aug 12, 2014 9:32 pm    Post subject: Reply with quote
I'm working from home tomorrow so a hour or two will be set aside for fettling and I might video the start up and running procedure.
I think you guys deserve to see and hear the results.
Richard
PostPosted: Tue Aug 12, 2014 10:52 pm    Post subject: Reply with quote
More self discipline than me....I'd be all day at it. Looking forward to the video.
PostPosted: Wed Aug 13, 2014 11:10 am    Post subject: Reply with quote
Certainly looking forward to the video. Congratulations on your achievements so far.
Rdover
PostPosted: Wed Aug 13, 2014 8:18 pm    Post subject: Reply with quote
So can I be but I need to pace myself given I've got other responsibilities. When preparing for rallies I reckon all 24 hours in a day are available for fettling but work and family always manage to get in the way!
Richard
Rdover
So, this afternoon, after rushing through all my 'real' work, I got busy with making a few changes and fettling the settings:
idle jet was 60 so changed for a 55 and idle mixture set to 1.5 turns out
comp jet set to 1.2mm (120)
new spark plugs fitted with gap set to 0.60mm
As ever the starting settings needed to be figured out but I got it running with a higher than ideal idle. Once warm I could play with the idle mixture and speed until it was running nicely and off for a wee test run up the hill.
Up hill from home
before: 1st gear and it made it eventually
after: was in 2nd before the rise and it ran up very easily almost wanting 3rd
Downhill
before: got to 4th but as soon as I was on the flat it died
after: easy on the throttle!!! I was doing 35mph before I knew it and it rattled along up and down the rises and wee hills in 4th between 25 and 35 mph.
Significantly better than it had ever been. Adv/ret is still questionable as is the main jet but it is very useable indeed and I am very pleased with it.
I then drove the 5 miles and back into Newton Mearns to collect my eldest daughter and then on to Stewarton to see a friend and back again. Dry conditions but very windy and it tripped along at 25 to 35 in 4th gear pretty much all the way. It will continue to improve as it runs in. I think I had about 5 litres in the tank and did 17 miles so I'll guestimate 15mpg to be safe and a range of 60 miles. I suspect it'll do more than that under ideal conditions but that is enough!
I've ordered yellow braided HT leads and brass thumbscrew connectors to make it look prettier and the list of jobs for the winter includes repainting the springs, making the rear spring firmer and remaking control rods, making the foot brake work properly, or at least better, and getting rid of all the remaining orange paint lurking under the chassis.
A wee vid for you all
[youtube]http://www.youtube.com/watch?v=MMLgmVgfhz4[/youtube]
Richard
PostPosted: Wed Aug 13, 2014 8:44 pm    Post subject: Reply with quote
http://m.youtube.com/watch?v=MMLgmVgfhz4
Sounds brilliant. Whole car looks exceptionally tidy
Page 25 of 32
