Hello, I have a 1965 austin ambridge A60 automatic, & I need some help.
The car was running fine until recently, when the engine became very uneven running at tickover & low speed driving. Now the problem has got worse & the car is virtually undrivable due to what seems to be constant 'missing' .
I have replaced all of the plugs, points, rotor, condensor & cap, but to o avail.
A friend advised that it might be to do with the valves, as the car has been run on unleaded petrol with one of those inline convertor thingies, or perhaps the coil might be faulty. Any help or advice would be much appreciated.
Thanks
Thanks Rick, I will change the coil & see if that does the trick I will also check all the bolts etc are tight. I have never checked compression before so don't know where to start. Do you know whether (if its a burnt / stuck valve), whether a redex shot in each of the spark plug barrells will cure it ?
Help is very much appreciated. Thanks again,
Mark
Joined: 27 Apr 2005 Posts: 11780 Location: S. Cheshire
Posted: Mon Sep 19, 2005 10:35 am Post subject:
For what they cost you may as well swap out the coil, and cross that off the 'possibles' list
You need a compression tester, these have an attachment that either pushes into, or (better) screws into, the plug hole. The idea is to spin the engine on the starter (remove the main HT lead from dizzy to coil, you don't want it starting!!) with the tester in one plug hole at a time, and make a note of the readings. You only need to churn it over for 5 seconds or so each time.
Have never tried Redex, but it wont cure the underlying fault - if there is one.
Posted: Mon Sep 19, 2005 11:46 am Post subject: compression tester
Thanks again Rick, I'm getting hold of a compression tester on 26th Sept. I will keep you informed !
Presumably if I get one reading lower than the other 3, that suggests a valve problem ?
Mark
Posted: Wed Sep 21, 2005 11:45 am Post subject:
A low reading could indicate a sticking or burnt out valve.
If you find a low reading, put a small drop of oil down the bore and do the test on that one cylinder again. If the reading stays the same, its probably a valve problem. If the reading goes up, you may have worn piston ring(s).
Posted: Tue Oct 04, 2005 11:21 am Post subject: cambridge
Rick,
thanks (again !).
Compressions all equal & 150 per cylinder, carb cleaned etc.
After all that, I managed to get hold of a new coil (with a screw fitting ht end !) & that solved the problem. So I'm now well pleased.
Only problem left now, is that since the carb was cleaned out (by a mechanic, before I fitted the coil), he adjusted the timing slightly, so the car is a little sluggish & pinks a little under strain.
I've never adjusted the distributor before, so any advice would be well received.
All the best
Mark
