The Long Road - Morris 8 Series 1
PostPosted: Sun Aug 01, 2010 9:46 pm    Post subject: Reply with quote
I can't believe this is taking so long. Rough cut for the carpets and get the seats mounted.
The headliner will be next, ooh I can't wait. Give me an engine to rip apart any day.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Mon Aug 02, 2010 1:11 pm    Post subject: Reply with quote
2 x tyres and 2 x tubes, £240 + carriage. Holy s***
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Fri Aug 06, 2010 7:50 pm    Post subject: Reply with quote
Carpet is in, just the gearbox tunnel to cover. Seats in, rear wing mounted, runningboard supports fitted, all electrics work (trafficator sluggish), headliner half in. I drove it under it's own steam today. - Great! I drove it towards the Midget and suddenly realised I had not tested the brakes. Confused
Setting the tension on the sewing maching is not easy, but practise makes, err, better. The edging is only pushed in at the moment. A few beers and bed, roll on tomorrow.
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
pryantcc
PostPosted: Sat Aug 07, 2010 9:21 pm    Post subject: Reply with quote
Great work! It all looks great!!
Ray the rocker
PostPosted: Sat Aug 07, 2010 10:32 pm    Post subject: post subject Reply with quote
they need a good seamstress in our local burtons outfitters--you just about fit the bill--whilst your there ,the staff cars might require a little servicing hehehe.it`s looking good--will turn a few heads when it`s finished--
cheers--Ray the Rocker....
PostPosted: Mon Aug 09, 2010 9:20 am    Post subject: Reply with quote
Ray do you need any trousers let out? I feel I am getting in touch with my feminine side then I think b*****ks, give me an oily spanner and a hammer. Very Happy
Thanks for the encouragement, not long now!
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Mon Aug 09, 2010 9:42 pm    Post subject: Reply with quote
Sometimes I get a bit confused. What hat should I wear?
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
P3steve
PostPosted: Tue Aug 10, 2010 7:14 am    Post subject: Reply with quote
So the Stig can sew as well!
PostPosted: Sat Aug 14, 2010 10:18 pm    Post subject: Reply with quote
Stig of the Dump maybe. I was mounting the running board but the rear wing was too far gone to bolt it to so I had to replace part of it.
A bit of smoothing then start to mount the boards. It's getting close now.
My partner Pat has just bought another car Shocked where are we going to put it?
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Ray the rocker
PostPosted: Sun Aug 15, 2010 9:31 pm    Post subject: post subject Reply with quote
better stitching there than the sewing machine--man of many talents indeed!! is that mig or gas? nice finish tho..
PostPosted: Mon Aug 16, 2010 11:07 am    Post subject: Reply with quote
Hi Ray, it's a cebora pocket Mig. Even set on lowest it still blows holes through the old metal if I try to do runs so I just spot along at approx 15mm gaps then fill in bit by bit. A bit slow but it seems (no pun) to work. The running boards are now both fitted, It took longer to do that than rebuild the engine (in hours). Just 2 tyres to fit and the head liner then nut and bolt check.......................MOT.
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Wed Aug 18, 2010 9:05 pm    Post subject: Reply with quote
It passed the MOT today, but was missing quite badly. It was running very rich so I swapped the float bowl from another carb and it is running a lot better. I will finish the rebuild while it is on the road. Very Happy
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Fluffle-Valve
PostPosted: Wed Aug 18, 2010 10:19 pm    Post subject: Reply with quote
This thread has been a fantastic read for me... Smile
Well done that man... Wink
Response call sign NH66
PostPosted: Thu Aug 19, 2010 8:24 am    Post subject: Reply with quote
Well done Nick
Must be something to do with the MOT that makes a car reluctant.
Mine did the same on the way to the MOT station, had to replace the coil in the middle of Maldon high street, consequently was late and just had to sit there till he could fit me in.
Three hours later MOT'd then blew the head gasket on the way home Rolling Eyes
Roger
PostPosted: Thu Aug 19, 2010 9:52 am    Post subject: Reply with quote
Perhaps the cars get "nerves" before an MOT.
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Page 5 of 7
Halfords
