1969 Fisher Holivan
HEJC72
PostPosted: Sun Nov 22, 2009 5:54 pm    Post subject: 1969 Fisher Holivan Reply with quote
I have a 1969 Holivan which has the beige quilted sides.
Unfortunately the handbook is long gone so I was wondering if anyone has any information about these little 'vans, particularly weights?
The stable door is towards the back on the near side with the kitchen across the back and a large wardrobe/toilet compartment in the rear off side corner. The parallel seating is 6' long which turns into a large double bed.
I need to do some work on the floor which is rotten near the entrance door.
At some time in the past there has been damp under the rear window which is now dry but doesn't look very nice!
I would also like to remove the old gas light at the front of the van and replace the 2 12v strip lights with LEDs.
Any advice on how to tackle these jobs or general comments about the Fisher Holivan would be much appreciated as there doesn't seem to be much info on the Net!!
I look forward to hearing from you.
rangerover125
PostPosted: Sun Nov 22, 2009 9:38 pm    Post subject: Reply with quote
Hi, the only problem you can have with leds is that they tend to be directional, so there is more chance of shadowing. You could try a row of high brightness ones, Maplins sell some reay for 12 volts.
I'm actually using some for a wireless trailer board that I've designed and am now building, best wishes Steve
