Rebuilding a Bristol 400
PostPosted: Sun Jan 03, 2010 5:00 pm    Post subject: Reply with quote
Ashley wrote:
It's even okay on fuel and will do 19 mpg on a run and 22 if you're pottering. It's extremely quiet like a good modern as well.
Yes, pretty impressive for 4.25/4.5 litres hauling 36 cwt, I don't know of any SS like mine that gets better than 19 mpg regardless of how it's driven, and it's only pulling 32 cwt. The opening windsreen on the SS ensures that it is not quiet like a modern car.
Ashley
PostPosted: Sun Jan 03, 2010 5:07 pm    Post subject: Reply with quote
I've fitted a 3.4 to 1 axle in place of the original 3.727 to 1 and I believe R-R concluded that your car was slightly under geared by their standards, which would mean very low. Mine is 3000 rpm at 75 mph.
Ash
PostPosted: Sun Jan 03, 2010 6:31 pm    Post subject: Reply with quote
True, but don't forget that standards were different pre-war.
Peter Wink
---------------SS Jaguar 2½litre-- Derby Bentley--SS Jaguar 3½ litre
Price--------------£395----------------£1510--------------£445
Length------------15' 6"---------------16' 0"--------------15' 6"
Width--------------5' 6" ---------------5' 8"----------------5' 6"
Weight------------32 cwt-------------34 cwt---------------32 cwt
Max Speed-------87 mph------------88 mph--------------91 mph
0 -60 mph--------17.0 sec----------17.1 sec ------------15.4 sec
0 -50 mph--------10.6 sec----------12.7 sec-------------9.0 sec
0-30 mph---------4.7 sec------------4.9 sec--------------4.1 sec
30-50 in top-------9.4 sec-----------8.0 sec--------------8.5 sec
30-50 in third-----8.1 sec------------6.6 sec--------------7.7 sec
mph/1000rpm----20.16 mph-------22.12 mph-----------21.34 mph
Test mpg----------19 mpg-----------17.5 mpg------------17 mpg
Ashley
PostPosted: Sun Jan 03, 2010 7:11 pm    Post subject: Reply with quote
The pre war Wraith was a superb car and rode and drove very much better than the Derbys although Rich says the MX was a lot better than the earlier cars. He's been involved in rebuilding quite a few when he was at www.alpineeagle.co.uk and is now www.richardjamesupholstery.com
The Jaguar I had did 90 relatively easily but was quite difficult to slow from that speed in that it started to snake and would bust the spokes in the back wheels if you weren't careful. I thought it was better proportioned than the standard Derbys too with a nice old engine.
The rods used to stretch rather than expand and I believe the same thing happens to Triumph motor bike engines.
Ash
PostPosted: Sun Jan 03, 2010 7:32 pm    Post subject: Reply with quote
Yes, I've had to replace quite a few spokes (inspite of having renewed the lot 16 years ago) but mainly as a result of cornering rather than braking.
Have been looking through the photos on your son's website. Very impressed!
Ashley
PostPosted: Sun Jan 03, 2010 9:18 pm    Post subject: Reply with quote
It wasn't braking with me either, it was getting up to 90, taking my foot off the accelerator and trying to cope with sometimes violent swaying. Some Derbys do it too and things can be improved by resetting the rear springs because they tend to sag and lose their tension.
Rich has done some famous stuff and is unusual in doing mechanical work as well.
Ash
Ashley
PostPosted: Mon Jan 04, 2010 10:20 pm    Post subject: Reply with quote
Here's the Bentley on the inside:
It is extremely comfortable.
Ash
PostPosted: Mon Jan 04, 2010 11:13 pm    Post subject: Reply with quote
Looks immaculate.
Have you kept your Radiomobile original or converted to semiconductor and FM?
Ashley
PostPosted: Mon Jan 04, 2010 11:29 pm    Post subject: Reply with quote
I've repaired/restored them in both the Bristol and the Bentley but not converted them to FM. I had one done in KDA and it was crap so I decided not to make the same mistake again.
I have a good spare too.
Ash
PostPosted: Mon Jan 04, 2010 11:43 pm    Post subject: Reply with quote
I used to run one from an under wing aerial in my SS. It was surprisingly good considering how shielded it must have been in there.
The RJF91 control box is not very intelligent so driving at night with the radio on was a bit either/or with other ancillaries like the heater blower or wipers but current drain wasn't the reason that I took it out.
I kept skinning my knuckles on it when changing gear. Rolling Eyes
http://www.jag-lovers.com/saloons/ss/ss10.jpg
http://www.jag-lovers.org/snaps/snap_view.php3?id=1117063708
Not a problem on the Mark VI though.
Ashley
PostPosted: Tue Jan 05, 2010 5:31 pm    Post subject: Reply with quote
The Bentley's have a special dynamo with plenty of reserve for most occasions, but the Bristol has a contemporary Lucas which is barely adequate.
R-R and B made all their own electrical equipment for years until they realised it was uneconomical so then they went to Lucas and made them set up a special department to make R-R bits and continued to be uneconomical!
They did the same with SU and their carburettors are different too.
Ash
PostPosted: Tue Jan 05, 2010 6:52 pm    Post subject: Reply with quote
It wasn't a lack of dynamo output that was my problem but rather the way the RJF91 reacted to increasing load. Even lightly loaded it doesn't fully maintain the battery charging current as you increase the load.
Whereas when Lucas brought in the RB340 things were much better controlled and increasing the load current didn't decrease the battery charge current. Leastwise up to the maximum specified dynamo output.
I could hide an RB340 behind the dashboard but I really prefer to experience the car (largely) as it performed originally.
Ashley
PostPosted: Tue Jan 05, 2010 9:49 pm    Post subject: Reply with quote
I'm not sure what the Bristol one's part number is but the Bentley has an RF95 which is the original. I've carefully cleaned the contacts and set it by the book and it wrks perfectly.
The Bristol is the same type but has extra terminals that presumably are to assist the wiring process. It seems to work, I have a spare I think and I've noticed that with everything on the system is only just holding its own.
Maybe I should set it up too!
Ash
scott_budds
PostPosted: Tue Jan 05, 2010 10:02 pm    Post subject: Reply with quote
Lovely looking cars, I lust after something like one of those!
Buddsy
Im looking for an Elan plus 2 for my next resto project...if you see one think of me please!!
PostPosted: Tue Jan 05, 2010 10:14 pm    Post subject: Reply with quote
If you set the engine running at say 2000 rpm in the Bentley and note the charging current, what happens to it as you switch on various loads? Does the charge current decrease gradually as you add loads or does it maintain the same charge current?
Mine gradually decreases the charge as I add more loads.
I think it still holds positive with headlamps and heater blower but if I were running the radiomobile on top, that would put me into discharge.
RF95 internals look similar to my RJF91 but I don't know if the regulators have the same series and shunt turns.
Page 2 of 3
