Dutch Ford 104E introducing
Goto page Previous  1, 2, 3
PostPosted: Wed Dec 31, 2014 10:55 am    Post subject: Re: Problem solved ! :D :D Reply with quote
Gerrit wrote:
After dinner i went check the 2 rods witch are on each side of the engine block.
And there i found the problem.
There are 2 supporting parts witch are each bolted with 2 bolts.
Bolts were lose !
After mounting the whole i made a test drive and problem solved.
Very Happy Very Happy Very Happy Very Happy
Problem I made myself by not fastening bolts during mounting sump. Rolling Eyes
John thanks for responce and a Good and Healthy 2015 for you and your family !
I had the same problem with my green E83W, one rod mounting bracket (on the E83W they are situated either side of the gearbox casing, not the engine) had snapped off, causing the problems you describe.
Glad to hear you got it fixed.
Farmer John
PostPosted: Thu Jan 01, 2015 7:25 am    Post subject: 104E Reply with quote
Well done Gerrit, and thankyou for your kind wishes.
John
Gerrit
PostPosted: Tue Aug 04, 2015 8:05 pm    Post subject: engine oil leak from bell house Reply with quote
The car always will spill some oil..
Thats because it is old.
But the spill got bigger.
And i thougt to find cause which was the round seal from sump
I replaced it now.
Spill is still to much.
Wat can cause the spill and how can i solve it ?
owner of:
1970/1975 chassis/rebuild FT Bonito kitcar
1954 Ford 104E
BMW bike K1
http://www.ftbonito.info
PostPosted: Tue Aug 04, 2015 11:47 pm    Post subject: Reply with quote
Did you soak the rope seal in oil for a few days, prior to fitting it?
ka
PostPosted: Wed Aug 05, 2015 7:42 am    Post subject: Reply with quote
I have tried many options to slow the leak from this seal. I even tried a system where it was replaced with a modern 'edge' seal, but wriggling it over the crank end, and then replacing the timing cover and sump was problematic itself, so back to the string seal.
My main leaks were caused by poor fitting of the string seal, (yes my fault). The seal must be entirely held within the recesses in the timing cover and sump, if there is an overlap, the seal will protrude from the recesses, and effectively deform the sump shape and allow a leak. With the sump bolts being away from the seal recesses, and a heavy reliance on the reinforcing plate behind the bolts, it is easy to tighten the bolts with the seal protruding holding the sump from the base of the crankcase, and allowing a leak.
Best of luck.
KA
Better three than four.
PostPosted: Wed Aug 05, 2015 8:02 am    Post subject: Reply with quote
I remember doing this job on my E83W years ago. Are the surfaces of the sump, where the bolts pass through, perfectly level?
Page 3 of 3
