Lubrication - Austin Westminster A90
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Mechanical
Dollywobbler
PostPosted: Tue May 11, 2010 2:22 pm    Post subject: Lubrication - Austin Westminster A90 Reply with quote
Hi folks
Wonder if you can help clear some confusion. I've just purchased a delightful Westminster, but the excellent handbook suggests that all grease points should be filled with 140W oil, whereas other have said that actual grease should be used. As I already have a 2CV, I have a grease gun loaded with grease but what should I be using on the Westy?
Ian
PostPosted: Wed May 12, 2010 1:10 pm    Post subject: Reply with quote
Welcome to the site Ian. Let's see some pictures then!
I am not sure about Westminsters, but most BMC cars of the time used grease in the nipples. My A35's certainly do.
1952 Austin A90 Atlantic
1958 Austin A35
1959 Austin A35
1958 Austin A55 Cambridge MK1
PostPosted: Wed May 12, 2010 8:18 pm    Post subject: Reply with quote
A lot of cars did use grease but equally quite a few MUST use thick oil like SAE140 as the passages are too narrow for grease to flow through properly
So check with other Westminster owners
Phil
PostPosted: Thu May 13, 2010 9:22 am    Post subject: Reply with quote
The Talbot does not like grease being used so I mix some EP90 with grease and that seems to work OK. The Morris likes it too. With the thinner lube the chassis etc should be looked at every 500 miles.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Mechanical All times are GMT + 1 Hour
Halfords
