Starter motor
Kelsham
PostPosted: Thu Sep 23, 2010 11:04 am    Post subject: Starter motor Reply with quote
Hi all, does anyone have knowledge of pre engaged starter motors ?
I have a Jaguar Xjs Cabriolet, it has taken to sometimes not engaging the starter motor.
I have checked the relay and switch, both ok.
Sadly the motor requires dropping one exhaust and the steering rack before removal.
I suspect the solenoid on the top of the motor is failing to engage. I can only see the connections with the aid of a dentist mirror. They are firmly connected.
Any insights? regards Kels.
