Bayliss Thomas
Posted: Fri Oct 01, 2010 11:30 am Post subject: Which contact breaker points? |
I need to change the contact breaker points fitted to my 1928 Vauxhall 20/60
The distributor is DELCO REMY model 656 KA. This distributor uses an double set of points and I have looked high and low trying to establish which are the correct items to purchase, my request net is also cast far and wide. Can anyone here assist please? |
michael1703
Bayliss Thomas
Posted: Fri Oct 01, 2010 6:58 pm Post subject: |
They do look very similar but I am not sure if they are the ones I need. I have emailed Holden asking. Thank you for the lead |
michael1703
Posted: Fri Oct 01, 2010 7:06 pm Post subject: |
If they arent the ones and they cant point you to the right ones, I'm pretty sure you can get Lumenition for your car
I know some people prefer points but if you cant get them then at least you have something |
traction39
Posted: Fri Oct 01, 2010 7:19 pm Post subject: |
Here is a potential supplier State-side. Small piece, low postage costs.
Check the stock list:
www.collectorsautosupply.com/DELCO.PDF
There is an email address at the bottom!
Alistair |
Bayliss Thomas
Posted: Sat Oct 02, 2010 11:48 am Post subject: |
Many thanks for all the leads, I will try A.Archer as first port of call, noted that they deal with vintage Vauxhalls, excellent. |
