canner
Posted: Mon Sep 23, 2013 4:31 pm Post subject: |
Finally found some time to crack on with cleaning up the underside....
this proved a very messy smelly job using a wire brush wheel on an angle
grinder, so I gave up on that idea, brushed on a little standard thinners and
scraped the old underseal off with an old chisel.....
canner
Posted: Mon Sep 23, 2013 8:40 pm Post subject: |
looks like you are doing a good job of it,does the air vent channel take in fresh air to cool or hot air out to heat and do they send it up the chassis leg? |
Posted: Tue Sep 24, 2013 8:11 am Post subject: |
Hi Canner,
Yes air is forced in the front of the truck through the chassis channels and this then cools the engine,
as it exits the engine it is heated more by the exhaust manifolds and is then channeled through tinware
and pipes back to the cab where you can choose to use it to heat the cab....
and not an ECU in sight thank goodness |
vitesse
Posted: Tue Sep 24, 2013 7:39 pm Post subject: |
Good job Steve all looks pretty solid underneath.
I assume you are going to recoat after any rust proofing etc required. I can't recommend enough that anti-chip I have been using. Easy to apply and good cover and a lovely rubberised finish. Tony |
vitesse
Posted: Tue Sep 24, 2013 7:43 pm Post subject: |
D4B wrote: | Hi Canner,
Is the air intake those two grills under the numberplate? |
Posted: Tue Sep 24, 2013 8:27 pm Post subject: |
Hi Tony,
Yes that's the air intake the two little grills in the lower front valence...
I may well use your stonechip rubberised paint in some parts, but most
of the underneath I shall use waxoyl shutz from a 1L tin applied via shutz
gun ~ mainly because that's what I have left over from restoring my D4B.
Pics will follow when I do it
Cheers Steve |
Posted: Thu Sep 26, 2013 1:31 pm Post subject: |
Glad to get this bit over and done with.... all reassembly from now on!
Posted: Thu Sep 26, 2013 3:35 pm Post subject: |
That's looking very nice. At least Mrs. D4B doesn't have to worry about the driveway...the drips should match.
I like that idea with the heat through the chassis. Does that keep the frame in good order. In the Fiat the heat's through a central tunnel with all the wires and cables and that part certainly never seems to rust. |
Posted: Thu Sep 26, 2013 4:35 pm Post subject: |
Rick: when I take the mattress to the local recycling centre I will be
sure to take along a photo of the TN7 sleeping on it, as a picture says
a thousand words......
Peter, yes I think you are porobably right, the heat must preserve the
metal because the chassis is one of the few bits I have not had to weld up!
Steve |
vitesse
Posted: Thu Sep 26, 2013 9:42 pm Post subject: |
Looks really good Steve. Like new. |
Posted: Mon Sep 30, 2013 4:21 pm Post subject: |
vitesse wrote: | Looks really good Steve. Like new. |
Tony, I wish it was new ~ I could enjoy using it then !
A little more progress, rear axle back in:
Posted: Mon Oct 07, 2013 5:48 pm Post subject: |
Driveshafts all stripped down and awaiting new CV Boots hopefully
tomorrow, and the old brake hoses are on their way to be remade
if possible fingers crossed!
vitesse
Posted: Tue Oct 08, 2013 9:54 pm Post subject: |
Ooh I missed all the updates yesterday Steve!!!
Looks like you are making good progress as well. Those bearings are different!
Is it difficult to get bits for the little Honda? |
