trampintransit
Posted: Sat Jul 04, 2015 9:43 pm Post subject: Dewandre servo |
Anybody got any experience of Dewandre remote brake servos?..most particularly why does it need a reservoir whereas modern servos don't? |
Calum
Joined: 07 Feb 2011 Posts: 100 Location: Midgley, W Yorks
Posted: Sun Oct 04, 2015 10:39 pm Post subject: |
Only just seen this...
My Series IIa Land Rover is an early 6 cylinder model, and they received Clayton-Dewandre remote servos as standard from the factory (they were only fitted for a couple of years and then replaced with a pedal-mounted Girling thing, I think it was). There is no reservoir to store vacuum if that is what you mean? The Girling remote servo on the P4, however, does actually have a reservoir tank under the offside front wing |
goneps
Joined: 18 Jun 2013 Posts: 602 Location: Auckland, New Zealand
Posted: Sun Oct 04, 2015 11:48 pm Post subject: |
I'm open to correction here, but my understanding is that all vacuum-assisted systems will have an accumulator/reservoir. With the type fitted since about 1970 this is integral with the master cylinder, whereas earlier systems employed a remote brake booster, essentially just a separate reservoir.
Having no reservoir would mean that if the engine stalled there would be no pedal assistance, whereas a reservoir provides enough capacity to bring the vehicle to a standstill with normal assistance. Furthermore, the amount of assistance could vary, which could lead to some interesting control issues.
Richard |
jp928
Posted: Wed Jun 08, 2016 7:16 am Post subject: Dewandre servo |
All the vacuum servos I have seen or used have some reserve capacity without an extra tank. I have a VH44 on a clubman, and despite its small size it gives at least 3 applications after dead engine. To test this, run the engine, stop it (in a quiet place- garage), and apply the brakes - you should hear a moving air sound as atmosphere enters the booster to apply pressure; repeat until you can no longer hear the air noise - thats your reserve applications. Extra Vac tanks were fitted to upper class cars like Jag, Rover, Humber etc to give more peace of mind. Once you have run out of vacuum, the pedal will feel different, not going down as far, harder.
jp
26 Rover 9 |
trampintransit
Posted: Sun Feb 26, 2017 7:28 pm Post subject: |
Gave up on the Dewandre....took advise stating that it was a rubbish Sservo when it was new so why bother trying to restore it. I've now rtro fitted a girling type for a Rover P5 _________________ '60 Armstrong Siddeley Star Sapphire
'80 Reliant Scimitar
'47 Jaguar MKIV --- in bits!!!! |
billysugga
Posted: Sun Feb 26, 2017 8:16 pm Post subject: |
Some of the Clayton dewandre servos were similar to bendix hydrovac but I don't know if yours would be the same. I am having similar problems with a bendix one. Parts and information are tricky. _________________ Volvo Sugga ,Volvo Trygge
I just wish one was working! |
