Paul fairall
Posted: Mon Apr 17, 2017 8:18 pm Post subject: |
GARAGE HERMIT wrote: | KA,
sound's like a lot of faffing about, for a few more bhp, not a road i'll be going down,
but good information all the same, ta,
another little question, the new aquaplane head's, are they std compression or bumped up a little bit, like fitting an 8hp head to a 10hp motor,? | bumped up a lot, something like 8.1:1 I'll look it up. There various combinations depending on head used and standard gasket and/or copper sheet of different gauges.
I have an 8hp head standing by if I decide to go that route. Priority is getting it to drive in a straight line and feel like I'm in control. _________________ 1957 ford popular |
ka
Posted: Tue Apr 18, 2017 7:59 am Post subject: |
Camshaft alterations are a time consuming matter. Easiest way is to fit an 8hp head to increase compression ration, and therefore torque. I fitted a machined 10hp head, 8.4 compression ration and a good flow area, in a car weighing 460kg good power to weight ratio. Aftermarket carbs and manifolds help, but to the cost of fuel consumption. All down to how much extra umph you are after.......................... _________________ KA
Better three than four. |
GARAGE HERMIT
Joined: 20 Mar 2017 Posts: 186 Location: stockton upon tees, cleveland,
Posted: Sun Apr 23, 2017 8:30 pm Post subject: |
steering wheel's a bit loose, measured as best i can the s/w nut,
i make it 1 1/2" AF, is that right ?,
before i buy a box spanner or maybe a deep socket,
cheer's, _________________ 1957 - 103e - popular, |
GARAGE HERMIT
Posted: Wed May 03, 2017 9:30 am Post subject: |
bought some landrover discovery alpaca leather 3rd row seat's to replace the std pop one's, which were terrible, like an old castiron bed spread, these are 100% better, took all the LR bit's off the bottom of the seat's, just have to make some mounting frame's now,
Last edited by GARAGE HERMIT on Thu Sep 20, 2018 3:00 pm; edited 1 time in total |
GARAGE HERMIT
Posted: Wed May 03, 2017 9:36 am Post subject: |
started taking all the bit's off the engine to fit the aquaplane part's, have'nt managed to get the head off just yet, proving a bit stubborn,
Last edited by GARAGE HERMIT on Wed May 03, 2017 9:28 pm; edited 1 time in total |
Posted: Wed May 03, 2017 10:49 am Post subject: |
I hope this isn't grandma's egg sucking.
Have you tried leaving the S-plugs in and then winding the starting handle to see if compression will start to lift the head? Perhaps tapping round the head with a hide or compo mallet while doing it. _________________ Bristols should always come in pairs.
GARAGE HERMIT
Posted: Wed May 03, 2017 11:00 am Post subject: |
penman,
thank's for the tip's, yes, did both, i've got it loose, but not loose enough to lift it off, put some penetrating oil on the stud's last night, i'll have another go at it today,
cheer's paul. _________________ 1957 - 103e - popular, |
Posted: Wed May 03, 2017 11:14 am Post subject: |
Wooden wedges.
Spokeshave or plane off bits of largish dowel/broom handle. _________________ Bristols should always come in pairs.
Paul fairall
Posted: Wed May 03, 2017 6:20 pm Post subject: |
GARAGE HERMIT wrote: | bought some landrover discovery alpaca leather 3rd row seat's to replace the std pop one's, which were terrible, like an old castiron bed spread, these are 100% better, took all the LR bit's off the bottom of the seat's, just have to make some mounting frame's now,
| i hope you are keeping the original seats as that looks a very nice car and will be worth more as original. I am making changes to mine but all will be reversible and I'm keeping all the original parts, i.e. the 6v Dynamo has been replaced with an alternator in a Dynamo case but I'm keeping the old Dynamo in case someone wants to put it back as standard in the future. _________________ 1957 ford popular |
Posted: Wed May 03, 2017 9:11 pm Post subject: |
One way I've shifted a sticky OHV head in the past is to make up some basic brackets to attach lifting tackle to the head itself, using the manifold and rocker studs. I don't know if you could manage something similar with this SV unit, but by lifting just the head the weight of the rest of the car soon persuades the corrosion to let go |
GARAGE HERMIT
Posted: Wed May 03, 2017 9:34 pm Post subject: |
bitumen boy,
i've no lifting gear or an A-frame, but thank's anyway,
as i mentioned, it's nearly there, just need's a bit more persuasion,
did'nt have time to do it today, out buying garden stuff for the wife, really enjoyed that, _________________ 1957 - 103e - popular, |
GARAGE HERMIT
Posted: Wed May 03, 2017 9:39 pm Post subject: |
i've bought some "woodhead" suspension mounting's, front and rear, anyone know what damper's fit these set up's, i think i read that old VW one's fit, but which one's,? _________________ 1957 - 103e - popular, |
Paul fairall
Posted: Thu May 04, 2017 3:59 pm Post subject: |
GARAGE HERMIT wrote: | i've bought some "woodhead" suspension mounting's, front and rear, anyone know what damper's fit these set up's, i think i read that old VW one's fit, but which one's,? | when you find out let me know I've bought the same. I haven't collected them yet from my mate. When I do I'll fit one and measure and allow for a bit more extension and compression. Vw heritage might be a good place to start searching. _________________ 1957 ford popular |
Joined: 14 Oct 2016 Posts: 1952 Location: East Yorkshire
GARAGE HERMIT
Posted: Thu May 04, 2017 7:43 pm Post subject: |
alastairq wrote: | http://www.justkampers.com/air-cooled-vw-parts/vw-beetle-parts/front-suspension-steering-bearings/front-shock-absorbers.html
KYB 211413031P.... [2nd from left] have an range from 27 cm to 41 cm.
AN enquirey to the above might get extended and compressed lengths for the shocks intended for lowered VWs? |
WOW, £62.75 each,
thank's alastairq, but a bit too rich for my blood, i'll keep looking, _________________ 1957 - 103e - popular, |
