Spring shackles
alanb
PostPosted: Wed Jul 24, 2019 11:26 am    Post subject: Spring shackles Reply with quote
Hi all can someone please tell me the correct procedures for tightening the shackle pins with castle nuts and split pins on leaf springs, is it tighten as much as possible and then back off one flat or just tighten until no play then pin at the nearest flat?
Alan
old tourer
Morris 8 two seater
PostPosted: Fri Aug 30, 2019 9:57 pm    Post subject: Re: Spring shackles Reply with quote
Alan
I also wish I knew the answer to that one as I am about to do the same job on my MG TC. I imagine you only need to tighten them enough to eliminate play and then put the split pin in. If they are too tight could they perhaps squeak?
PostPosted: Sat Aug 31, 2019 2:05 pm    Post subject: Reply with quote
Surely if the bush has a spacer tube the nut must fully be tightened (with car weight full on) to its shoulders - backing off sufficient to fit the split pin
Rover P2
Morris Mini Traveller Mk2
alanb
PostPosted: Mon Sep 02, 2019 1:29 pm    Post subject: Reply with quote
Phil,
The Morris 8 doesn't have rubber bushes it has a bronze bush in the spring with bronze spacers either side. I tightened them as tight as I could then backed them of until I could just turn the spacers and put the split pin in been on a couple of short runs and the car seems ok much smoother than with the old springs and even steers better. Good luck with the MG Ray.
old tourer
Morris 8 two seater
PostPosted: Mon Sep 02, 2019 2:55 pm    Post subject: Reply with quote
Thanks Alan.
I have taken the n/s rear spring apart. There is a fair amount of rust so I plan to sand blast it and apply corn head grease before re- assembling. The clamps should have rollers but they are missing and just bolts remain which have worn half through. I have a length of brass tubing which will fit snugly over some new bolts and I am hoping when packed with grease they will work as intended.
alanb
PostPosted: Mon Sep 02, 2019 6:12 pm    Post subject: Reply with quote
Mine looked ok until I hit a pothole and broke one, still Jones Springs of Wolverhampton made me a nice new pair for a reasonable price and now it drives much better.
old tourer
Morris 8 two seater
PostPosted: Mon Sep 02, 2019 8:46 pm    Post subject: Reply with quote
Ray, what's corn head grease? Never heard of it before now.
PostPosted: Mon Sep 02, 2019 8:54 pm    Post subject: Reply with quote
https://www.cenex.com/~/media/cenex/files/lubricants/cornhead%20grease/corn%20head%20grease_pds-h9-02.ashx
When I Googled for it I noticed that the John Deere brand Cropped Smile up a lot so that gives a clue to it's Major Smile uses.
Please excuse the punning. Very Happy
PostPosted: Mon Sep 02, 2019 9:16 pm    Post subject: Reply with quote
There is nothing special about corn head grease; in fact it is only suitable for low speed use so never put it in axles, gearboxes, etc.
What I can say is that it tends to stay put until heated so it is great for use it on winches, leaky steering boxes or in this case leaf springs. Farmers like it for their machinery.
