Posted: Tue Feb 25, 2020 9:39 am Post subject: O/T 240v inverters |
In the cellar we have a sump set into the floor, into which water drips, it's about the size of a large bucket. There's a 240v pump (connected to the mains via a 3-pin plug) sat in it which kicks in when the water reaches a certain level, and pumps it outside. It operates on a fairly regular basis, much more so when the ground is very saturated, for a few seconds at a time.
This works fine, unless we have a power cut. I bought a petrol generator to cater for such purposes a few years ago, but obviously this is only effective if we're around.
Can anyone recommend a way of providing an independent 240v feed to the pump, to cater for power outages when we're away.
I've read a little about 240v inverters, but would welcome advice on how such a system might be put together, and what I'd need. Would small solar panels work, keeping a 12v battery topped up?
thanks, RJ _________________ Rick (OCC Admin)
Posted: Tue Feb 25, 2020 9:59 am Post subject: |
This is pure speculation, but could you rig up a float that when it reaches a particular point operates micro switches to turn the generator on and then operate the starter.
If it is a cord pull starter can an electric starter be fitted.
How do stand-by generators kick-in automatically? _________________ Bristols should always come in pairs.
Joined: 23 Nov 2007 Posts: 3654 Location: South Cheshire
alanb
Posted: Tue Feb 25, 2020 11:53 am Post subject: |
How much power does the pump draw when running? Most reasonably priced inverters have a fairly low output, if the inverter output is sufficient you could run the pump through the inverter and keep the battery topped up with a smart charger permanently connected. _________________ old tourer
Morris 8 two seater |
Kenham
Posted: Tue Feb 25, 2020 7:02 pm Post subject: |
I think the only thing to have would be a Lister Start O Matic diesel generator down in the cellar, it would be nice thumping away under the house. |
Farmer John
Posted: Tue Feb 25, 2020 7:59 pm Post subject: Sump pump |
Hi Rick. Dave has it using equipment made for the job. Also good advice re inverters.
John |
