Posted: Fri Feb 21, 2020 1:31 pm Post subject: |
I've always thought that the coolant should be visible at the top of a conventional radiator. It needs to cover the top of the radiator tubes or presumably, there's no flow through the system.
& does it matter if the expansion tank is above or below the top of the rad?
Does it make any difference if you use a pressurised or non-pressurised rad cap? _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
alanb
Posted: Fri Feb 21, 2020 2:12 pm Post subject: |
I had a Citroen BX that was extremely difficult to fill without getting air locks as the expansion tank was lower than the engine and radiator although it did have bleed valves in the pipe work by the heater and carburettor, the way they did it at the garage was with a large bottle that fitted over the expansion tank taking the water level above the engine and heater and then filled it with all the bleed valve s open and the engine running.
If you have air in the system then the air will expand much quicker and much more than water thus forcing the water out, the other possible cause could be a build up of pressure caused by a leaking head gasket, have you tried testing the water system for gases? _________________ old tourer
Morris 8 two seater |
Joined: 30 Apr 2013 Posts: 3813 Location: The Somerset Levels
Posted: Fri Feb 21, 2020 2:36 pm Post subject: |
The Commer has an expansion tank approx. 12 inches above the radiator. The operators manual states that the coolant level should not be seen in the expansion tank but when she boils up the water level rises up the 12" of pipe into the expansion tank. _________________ Various Rootes Vehicles. |
Posted: Fri Feb 21, 2020 2:41 pm Post subject: |
Just another thought:
You have a 'header overflow pipe' and an expansion tank. Are they connected in the right sequence? Or do you need both? I'm thinking that the overflow should be from the expansion tank, not the radiator header.
Wiki refers to the engine as a 'Commer Knocker'! _________________ Mike - MVPeters at comcast.net
Posted: Fri Feb 21, 2020 5:07 pm Post subject: |
Rootes you mention that the banging "starts slow and quiet then increases in frequency and volume". If the frequency of the banging doesn't follow the engine revs then I think I would rule out the water hydraulic theory.
Posted: Sat Feb 22, 2020 10:38 pm Post subject: |
Rootes75 wrote: | The Commer has an expansion tank approx. 12 inches above the radiator. The operator's manual states that the coolant level should not be seen in the expansion tank but when she boils up the water level rises up the 12" of pipe into the expansion tank. |
I wonder if you might try something?
If there is a cab heater, be sure any valve to that is set to 'hot'.
Then take the radiator cap off & fill it slowly but via the header tank. Despite the manual, a little visible water won't matter. The rad should overflow, but at least you're guaranteed a completely full system.
I think the pressure cap should be on the expansion tank, not the rad. Some expansion tanks have a 2nd inlet port for a rad overflow - re-cycling the coolant.
I'm not sure about the rad overflow being open to the atmosphere - won't it just burp water out? Perhaps you could temporarily block it off.
I'll bet you've already tried all this!
The banging might possibly be water suddenly hitting very hot steel & instantly turning into super-heated steam. This can be very violent - ask any traction engine owner! _________________ Mike - MVPeters at comcast.net
Posted: Sun Feb 23, 2020 1:14 pm Post subject: |
Thanks for all your suggestions, we are going to try out lots of theories before we do anything drastic like taking the head off etc.
Its good to get ideas from everyone, we all have a different take on things and to me this is what the forum is all about. _________________ Various Rootes Vehicles. |
Clactonguy
Joined: 20 Mar 2018 Posts: 104 Location: clacton on sea
Posted: Sun Mar 01, 2020 8:54 am Post subject: banging? |
interesting thread and a lot of good suggestions . though I understand some garages can leak test engines using pressure testing ( cylinder and coolant) plus chemical tests. though not directly involved in these checks so only have word of mouth as it were. If it was my engine depending on cost /time of things would go through process of checking pressure in system and assuming we think internal coolant leak ..topping up required often? ..then would think about changing head gasket and having head checked for flatness or lightly skimmed too. is there a 'commer' forum at all? and have we bounced the issue of other sites such as 'petrol heads' .good luck and do update please so we can all find out final fix. |
Posted: Sun Mar 01, 2020 10:21 am Post subject: |
leak down testers can be purchased for less than £25 these days If you have a compressor it would be worth getting one as it will quickly identify if there is a leaky cylinder and where its leaking from.
Far more informative than a compression test.
