Mayflower compression
Rollmop
PostPosted: Mon Oct 26, 2020 12:39 pm    Post subject: Mayflower compression Reply with quote
Has anyone had a compression test done on a Triumph Mayflower engine?
I tested mine to check the cylinder head gasket and get a reading of 73 to 75 psi across the four cylinders. None of the Triumph technical manuals I have seen give a pressure value, is around 75 psi about right for a low mileage engine? Any info/experience would be much appreciated.
Failure is not an option - in my case it is usually a feature.
1971 Herald convertible
1952 Triumph Mayflower
PostPosted: Mon Oct 26, 2020 2:37 pm    Post subject: Re: Mayflower compression Reply with quote
I would think that is a bit low but the main thing is that they are all more or less equal.
Sid
PostPosted: Mon Oct 26, 2020 10:04 pm    Post subject: Reply with quote
To calculate the compression in PSI, and if you know the compression ratio, multiply the first figure by 14.
edit....which is 6.8:1, therefore a compression of 95psi.
PostPosted: Tue Oct 27, 2020 12:43 pm    Post subject: Re: Mayflower compression Reply with quote
Agreed, if it runs and drives ok I wouldn't be concerned.
PostPosted: Tue Oct 27, 2020 3:59 pm    Post subject: Reply with quote
The test need so be completed with the throttle wide open, otherwise it will read low.
Rollmop
PostPosted: Fri Oct 30, 2020 12:43 pm    Post subject: Reply with quote
Thanks for the CR formula. Once you see it it is a very obvious calculation, atmospheric pressure x compression factor. I will leave it for now but next year may have the head off to check the pistons, bores etc
