new mystery with my Humber imperial
Traumjaegercat
PostPosted: Thu Jan 07, 2021 5:47 pm    Post subject: new mystery with my Humber imperial Reply with quote
Hi All,
After sorting out the smoking problem I re-set up my twin Stromberg barbs as per the workshop manual and the car started first go and ran well for a few hours. After coming back to it a few days later it started playing up. It would fire and run rough for a few seconds then spit out of both carbs and stop. Tried to start it a few more times with the same result but it would run slightly longer but I could not keep it running. Every time it spat it would stop. I could not even apply any throttle pressure. This car is driving me mad.
Can anyone out there give me some ideas on what is happening and the cure.
Many thanks
T
Twisted Evil Twisted Evil Twisted Evil
PostPosted: Thu Jan 07, 2021 6:13 pm    Post subject: Reply with quote
When you said Strombergs my first thought was the diaphragms.
Brent29
PostPosted: Thu May 06, 2021 10:34 pm    Post subject: Reply with quote
Have you sorted it out?
Traumjaegercat
PostPosted: Sun May 09, 2021 6:15 am    Post subject: Reply with quote
Thanks for inquiring. The short answer is no and the smoking has come back.
However, I was so fed up with all the problems and decided to pull the motor and go for a re-build.
Took the head in to my local engineering shop for them to start work on the overhaul and they immediately came up with some problems such as a couple of burnt out valves and some worn guides. Now the problems start again. I can't find anyone that has guides for this engine. Does anyone know of anywhere I can get some. The engine is the Rootes group 3 litre as used in the Super snipe and the Imperial. Or has anybody any ideas on how I can get these refurbished or made somewhere. On the car shows on TV such as car S.O.S they seem to find everything that they need. (If only I was that lucky)
Looking forward to some replies
Many thanks
T
PostPosted: Sun May 09, 2021 8:14 am    Post subject: Reply with quote
Many thanks
T
Have you tried Speedy Spares? they do Rootes parts.
Rick (OCC Admin)
PostPosted: Sun May 09, 2021 8:45 am    Post subject: Reply with quote
Might be worth speaking to Glen at Norfolk Humbers (07799 216533)
http://www.norfolkhumbers.co.uk/
PostPosted: Sun May 09, 2021 9:48 am    Post subject: Reply with quote
I believe many engine builders can get any sort of guide turned up?
Even in phosphor bronze, if preferred?
[Providing, I presume, they are simple 'tubes'?]
PostPosted: Sun May 09, 2021 11:05 am    Post subject: Reply with quote
When I needed to source valve guides for pre war Morris's before getting a manufacture quote, I scoured modern guides and found one with the correct dimensions;
https://www.intervalves-technologies.com/wp-content/uploads/catalogues/Intervalves-Technologies-Catalogue-Valve-Guides-2019-11.pdf
