Goto page Previous  1, 2, 3 ... 141, 142, 143, 144  Next
Vintage Fly Guy
PostPosted: Sun Oct 05, 2025 10:10 pm    Post subject: Reply with quote
Not so much what I did with my car today, but last Monday. I took it to a specialist classic car restorer to have the few 'bits and pieces' that were just starting to get a bit 'edgy' attended to.
I'd wrestled for a few years about whether or not to do this to an otherwise 100% factory original car, but eventually common sense won out, as those 'little bits and pieces' where corrosion was beginning to start would not stay little bits and pieces forever, and would eventually grow to require much more drastic work, losing far more original paintwork, than if if I had them professionally 'nipped in the bud' now, while there was still sound metal beneath to work with.
Fingers crossed, it's in excellent hands; I think mine is currently the cheapest car in there! It's stable mates include some sort of late '50s early '60s Ferrari hard-top coupe (stripped to a bare shell, placed on a spit and the subject of much new metal being carefully shaped and crafted in), along with two E Types undergoing similar treatment, plus a 1940s Rolls.
When I went to check them out a few months back, they had a Ford GT40 and a Ferrari Testarossa in there to, in varying states of undress, which have now been completed and returned to the wild.
It's still a bit unnerving sending a much-loved classic car in for work, even if relatively minor, so wish me and the car luck!
In the meantime, I'm getting on with painting the garage floor (I know my place!), so it should be dry by the time I get the Range Rover back.
Last edited by Vintage Fly Guy on Sun Oct 05, 2025 11:42 pm; edited 1 time in total
PostPosted: Sun Oct 05, 2025 10:17 pm    Post subject: Reply with quote
I hope you get the Range Rover back with all the work done to your satisfaction. Remind us please, what model is it?
Vintage Fly Guy
PostPosted: Sun Oct 05, 2025 11:27 pm    Post subject: Reply with quote
Thanks Ray. It's a 1992 Vogue EFI 3.9 manual in Ardennes Green, which has been in the family from new and has just 47,800 miles on the clock.
You'll have probably seen it crop up occasionally in some of Rick and Harley's YouTube videos, as it's been to a few of the local car meets over the last 18 months or so (on dry days only! Wink )
Hopefully, once the work is done, it will continue to look like this for the foreseeable future, not slowly deteriorate. I don't know why, but I love the bloody thing; and it's a nice connection with my late father, who bought it new.
consul 57
PostPosted: Fri Oct 17, 2025 3:19 pm    Post subject: column gear bushes Reply with quote
after the gears were getting harder to find when the car was hot i decided to investigate the rubber bushes on the consul column gear rods, gearbox end.
found quite a bit of play, i had changed the engine end a few years ago but put off the gearbox end as it is an oily mucky job with plenty of oil & grease around the rods.
now new rubber have taken up all the play and it seems to go into gear a lot better.
test run over the weekend i think.
another job off the 'to do' list for the winter.
PostPosted: Fri Oct 17, 2025 5:02 pm    Post subject: Re: column gear bushes Reply with quote
I remember my Dad having that issue. I think he was relieved it was nothing more serious.
Incidentally, I found a nice Consul with an unspoilt interior.
https://www.carandclassic.com/car/C1914375
Unfortunately it has fallen into the hands of a dealer; hence an unrealistic asking price!
consul 57
PostPosted: Fri Oct 17, 2025 5:55 pm    Post subject: Reply with quote
yes not too bad a job, easy & cheap fix!
that consul looks nice except the red? should have sprayed the whole car i think.
PostPosted: Fri Oct 17, 2025 7:29 pm    Post subject: Reply with quote
If the price had reflected the paintwork needed, I think it could be a nice SPQR for someone.
consul 57
PostPosted: Sat Oct 18, 2025 10:19 am    Post subject: Reply with quote
mine is valued at a few grand less than that and does not have contrasting boot & under bonnet colour, but a dealer would charge more to make a profit but some do think they have a gold mine with old cars sadly.
it is only money after all, lol.
PostPosted: Mon Oct 20, 2025 9:22 pm    Post subject: Reply with quote
I have had no chance of sorting out my TC lights as the P38 is coming up for it's M.O.T. and I need to somehow get the wiper washers working again. The reservoir is full and the pump motor is making a noise; I presume it is working... and so there must be a blockage somewhere.
I was also delayed by fitting new door mirror glass (both sides had discoloured badly) and then the battery went flat with the car stuck across the drive...YES, AGAIN!
Jean was not well pleased. Mad
bjacko
PostPosted: Tue Oct 21, 2025 6:13 am    Post subject: Wiper washers Reply with quote
The Washers on my Rover work alright for the front windscreen but the rear one has never worked. I traced the tube all round the front end and then it disappeared into the body where it appears to be disconnected. So one day I will have to try and get it fixed. It is probably behind the headlining. I can't do much these days - old age!
Hope yours is easier to access?
1985 Rover SD1 VDP
PostPosted: Tue Oct 21, 2025 7:39 am    Post subject: Reply with quote
I have previously had issues with the inline non return valves
PostPosted: Tue Oct 21, 2025 8:35 am    Post subject: Reply with quote
I swapped the rear dampers and drop links on the daily driver the other day, to try to remove or reduce the clonks coming from the rear end. It's probably helped a little, but not as much as I hoped it would. The dampers are stiffer than the ones I took off, but there are still more clonks than I'd like.
By way of thanks for me spending some money on it, it's now being difficult to start after it's been left overnight. Once it's going, it'll be fine all day, but it's concerning first thing. I have visitors later in the week, so it's a concern, and I have to get it booked in for MOT soon as well.
PostPosted: Tue Oct 21, 2025 9:24 am    Post subject: Re: Wiper washers Reply with quote
The pipework is a plumber's nightmare and someone thought it would be a good idea to mount the washer pumps behind the front bumper. According to scripture, to get to them the bumper and front grille have to come off! After 25 years the bolts are more likely to shear off rather than unscrew...but I have a cunning plan.
I think I should be able to get enough access by removing a built in spot lamp, but even this is not straightforward. If the electric pump works I could take a new line to the nozzle, or if that is no good I could fix up a manual push pump.
Getting desperate now!
PostPosted: Tue Oct 21, 2025 4:09 pm    Post subject: Reply with quote
A quick update. I have checked that the nozzles are clear and they seem to be.
The bumper removal - contrary to my fears - couldn't have been easier. There were just two bolts which came out easily and the ends slid into plastic retainers on either side. It has obviously been of before and gave me good access to the three washer pumps in the base of the reservoir.
Unfortunately the battery went flat again before I could operate the switch to determine which of the three pumps on the bottom of the reservoir feeds the windscreen washers. I am also unable find a wiring diagram for the car so I can't establish which is which by the wiring colours.
I am thinking of disconnecting the rubber hose and seeing if the relevant pump is working. If it is, the next suspect is the non return valve.
PostPosted: Tue Oct 21, 2025 5:23 pm    Post subject: Reply with quote
As you look at it the right hand pump operates the windscreen washers. In fact the pump is fine. The problem is a non return valve. Of course, it is difficult to get at but perseverance pays and a new one will be sourced.
Incidentally, I am thinking of re instating the headlamp wiper/washers but as we know it all takes time...
Page 142 of 144
