steveglazier
Joined: 24 Feb 2008 Posts: 11 Location: Stoke on Trent
Job-Rated
Posted: Fri Mar 28, 2008 11:56 am Post subject: |
Saw you sign up to the NSRA board...
Welcome here, too. _________________ Don't run your fingers over my truck & I won't run my truck over your fingers!
stuchamp
Posted: Fri Mar 28, 2008 1:49 pm Post subject: |
Welcome aboard! |
steveglazier
Posted: Fri Mar 28, 2008 1:53 pm Post subject: |
THANKS this is the Anglia i bought less engine so was ideal for what i wanted, at the moment it is strippet . all it requires is two sill's and a small patch to a rear arch and some time cleaning the rust areas.
still spending money on bits so have no date set to finish it
[img][/img]
steveglazier
Posted: Sat Apr 05, 2008 11:33 am Post subject: |
No its not straight forward: The little sidevalve engine that sat there did not requre a lot of room so to put a biger engine in requires the bulk head to be cut and pushed back & the gear box tunnel to be cut. then there is the rest of the mods cross member, Back axle, brakes, front suspenion, better wipers not vacum fed.. Thats why i jioned the 100e forum & this site to get as much help with info and parts. |
Posted: Sat Apr 05, 2008 4:21 pm Post subject: |
Welcome! |
Downton
Posted: Sun May 18, 2008 5:15 pm Post subject: So what engine you putting in? |
Well fancy seeing you here!... |
