Cough cough splutter splutter shudder shudder...
Goto page Previous  1, 2
PostPosted: Sat Aug 08, 2009 9:17 am    Post subject: Reply with quote
Yes, I'd check the distributor cap for cracks.
Richard Hughes
PostPosted: Mon Aug 10, 2009 1:23 pm    Post subject: Reply with quote
Had a similar problem years ago with an A35. Coil mounted on the dynamo. The clamp around the coil had cracked the coil case and it was slowly loosing oil. Eventually it displayed exactly the symptoms described.
Only found it because the vehicle appeared to have an oil leak where there was no oil!!
PAUL
TTotal
PostPosted: Mon Aug 10, 2009 7:07 pm    Post subject: Reply with quote
Wedding went very well (see my Facebook page for pics!)
Interesting thoughts about the distributor area... Wink
Cheers all
John Very Happy
PostPosted: Mon Aug 10, 2009 7:19 pm    Post subject: Reply with quote
Hi John
How about joining the oldclassiccar facebook group (It's called Oldclassiccar) Very Happy
I'm Richard Hughes on there Wink
Richard Hughes
PostPosted: Tue Aug 11, 2009 4:12 pm    Post subject: Reply with quote
I don't think - up to now - that a clogged air filter has been mentioned. An engine needs lots of air as well as fuel and will not run well with a shortage of either. You say "pulling the choke out makes no difference", which it probably won't if the air filter is clogged.
TTotal
PostPosted: Tue Aug 11, 2009 9:03 pm    Post subject: Reply with quote
(Wahoo still married after 6 days!) Laughing
Air filter eh? Must have a peak this weekend. THANKS!
John Smile
TTotal
PostPosted: Mon Jan 11, 2010 10:24 am    Post subject: Reply with quote
and.......... months later!
It was a carb full of water!
Cleaned out fuel pump, carb, tank and fitted new filter. Also new rubber seal on filler cap just in case.
2,000 miles later all fine.
He goes on and on, brilliant too in the snow as tyres are narrow.
Page 2 of 2
