Posted: Thu Sep 24, 2009 11:48 pm Post subject: 2 pak primer! |
If I have a primed surface, can you top coat in 2 pak, or does it have to be a 2 pak primer?
bob2
Posted: Fri Sep 25, 2009 10:11 am Post subject: |
| I have used 2 pack directly on red oxide without any problem so far and its been on for more than a year now though its not exposed to the elements!! |
peppiB
Posted: Fri Sep 25, 2009 1:53 pm Post subject: |
| I was told that 2 pack would happily go over cellulose, but not cellulose over 2 pack. My 1800 was sprayed in 2 pack covering cellulose primer, and after a year there are no signs of any problems |
Posted: Fri Sep 25, 2009 2:45 pm Post subject: |
| Yep you can use 2 pack top coat over acrylic /celly primer. |
Posted: Fri Sep 25, 2009 8:14 pm Post subject: |
Celly goes really well over hardened 2 pack as long as you can finish the edge on line or swage as it does not blend/flow in _________________ Rover P2
Posted: Fri Sep 25, 2009 10:47 pm Post subject: |
Excellent, thanks!  |
