Pancake Filters
Finch661
PostPosted: Wed Oct 07, 2009 4:25 pm    Post subject: Pancake Filters Reply with quote
last question for today (honest). are there any benifits of fitting pancake filters (those flat chrome ones) rather that standard paper ones?
cheers Evil or Very Mad
1985 Mini Mayfare (1275)
1976 Mg Midget 1500
PostPosted: Wed Oct 07, 2009 10:49 pm    Post subject: Reply with quote
Keep your car standard. It's a lot easier to service if it is as the maker intended it to be. I found the HS4s would not richen enough to mess with the air filters.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Finch661
PostPosted: Thu Oct 08, 2009 10:00 am    Post subject: Reply with quote
did you try to change the needle? i was reading the midget restoration manual and it discussed that they changed the exhaust on the 1275/1500 to make it a lot quieter. i pulled up next to a MGB-GT, and the noise coming from the exhausts was amazing.... i would like a more grunty exhaust note (not in a boy racer way mind!!! Smile ) and hoped that maybe changing the filters would help
1976 Mg Midget 1500
victor 101
PostPosted: Thu Oct 08, 2009 10:31 am    Post subject: Reply with quote
Changing air filters wont effect the noise the exhaust makes, but might make the engine sound a little different.
Finch661
PostPosted: Thu Oct 08, 2009 11:40 am    Post subject: Reply with quote
ah well. i might stick to the "if it aint broke dont fix it" idea
1976 Mg Midget 1500
PostPosted: Thu Oct 08, 2009 1:55 pm    Post subject: Reply with quote
My 1500 has a standard exhaust on it and it gives a lovely little rasp when a bit of throttle is used. You will soon get sick of having to turn the radio up on long trips if you mess with exhaust/filters. Also while I am here, I keep hearing other people (MG owners club) whinging about the 1500 overheating but I do not have this problem even in heavy traffic (stuck for 1 hour on the M25). I think the reason is I use 10/40 semi oil and I have done away with the heater valve at the back end of the engine and put a straight through piece of hose. A double skin heat shield between the exhaust and carbs is a must.
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Finch661
PostPosted: Thu Oct 08, 2009 2:54 pm    Post subject: Reply with quote
my engine overheats as well. though i found that even with the heater in the cold position, the cab always became hot! i will pick up a new heat shield as my current one looks knackered!
it does have a nice roar when you open her up!
1976 Mg Midget 1500
PostPosted: Fri Oct 09, 2009 12:15 pm    Post subject: Reply with quote
If some of your cooling tubes in the rad are blocked that will cause it to overheat.
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
