My 1957 A35 "Black Pig"
bertie
PostPosted: Wed Nov 04, 2009 8:08 pm    Post subject: Reply with quote
just love the float chamber! What`s in the tank should be interesting... Shocked
Brian M
PostPosted: Wed Nov 04, 2009 9:36 pm    Post subject: Reply with quote
Rich
I snapped the half shaft on my Frogeye, back in 1970!
I had to do the repair at the kerbside. The shaft was out in 15 minutes or so but it took four more hours to get the inch of the broken splined end out of the diff.
Good luck with your repair.
Brian
PostPosted: Thu Nov 05, 2009 12:21 pm    Post subject: Reply with quote
Brian
That is exactly the problem I've got at the moment! The broken off piece is stuck in the diff so it looks like the diff housing will have to come apart to get it out. This is made even more difficult by the fact that the car isn't drivable so we can't get it on the ramps Sad
Removing the halfshaft was the easy part.
1935 Standard Twelve
1953 Austin A40 Somerset
1958 Austin A55 Cambridge
1959 Austin A35
1980 Vauxhall Royale 2.8 auto
1987 Austin Maestro 1.3 L
PostPosted: Thu Nov 05, 2009 1:51 pm    Post subject: Reply with quote
I guess you've tried lassooing it with a noose of wire?
Peter Sad
1939 SS Jaguar 2 litre saloon
PostPosted: Thu Nov 05, 2009 4:56 pm    Post subject: Reply with quote
It's stuck in too far. I tried fixing a magnet to the end of a long pole and sticking it up the tube, but the broken off piece seems to be jammed tight. Oh well. I have got the car up on axle stands so I can now make a start on the diff bolts. Sad
1959 Austin A35
Keef
PostPosted: Tue Nov 17, 2009 6:56 pm    Post subject: Reply with quote
Did you sort it in the end Richard?
Keef - Sheerness Kent UK
PostPosted: Wed Nov 18, 2009 1:30 am    Post subject: Reply with quote
This might be a bit late!
Since you've got to take the opposite half-shaft out anyway, to get the diff out, can't the broken bit be punched out from the other side?
This probably depends on the design of the diff, but I seem to recall it worked on my '34 MG J2 which had a Morris 8 rear axle.
I think the Morris half-shafts were over-powered by the awesome power of the Aquaplane Ford engine!
Mike
PostPosted: Thu Nov 19, 2009 6:27 pm    Post subject: Reply with quote
I got the A35 back on the road last week. In the end I had to remove the diff, but once it was out the broken piece of halfshaft could easily be pushed out. A quick going over with a magnet to remove all traces of swarf then back in. A new fuel filter was a five minute job to fit, which involved cutting a small section (about 5 inches) out of the fuel line. Touch wood, the Austin seems to be running well, although the double-declutching necessary when changing gear, combined with a heavy clutch pedal, make driving in traffic very tiring Sad
1959 Austin A35
Keef
PostPosted: Thu Nov 19, 2009 7:38 pm    Post subject: Reply with quote
Glad to hear you are back on the road. Smile
Not a bad idea to remove diff anyway as it allows you to remove any swarf as you say.
PostPosted: Fri Nov 20, 2009 11:04 pm    Post subject: Reply with quote
A couple of pictures from the job:
snapped halfshaft.
Yesterday I was idly browsing the A30/A35 Owners Club website when I saw a load of A35 parts free to good home. So I went down to Bexley today, and came back with loads of great parts, a mixture of new, new old stock and good secondhand items which I am very pleased with. There are rare parts such as an original grill muff, recon carb, BMC inner sill panel, boot hinges, new gear gaitor, window glass, distributors, master cylinder, new pedal rubbers, indictor lenses, and loads of other stuff Very Happy
And the Black Pig with its proud owner Smile
Note the bent bumper caused by towing - if anyone has a pair of decent saloon bumpers I would like to hear from them.
1959 Austin A35
PostPosted: Fri Nov 20, 2009 11:24 pm    Post subject: Reply with quote
cooo neat haul of bits there Smile
Rick (OCC Admin)
Keef
PostPosted: Sat Nov 21, 2009 1:03 am    Post subject: Reply with quote
You should have called in for a cuppa and to see Reckless.
I see your drive is the same as ours. Smile
PostPosted: Sat Nov 21, 2009 11:20 am    Post subject: Reply with quote
I should've done, next time I'm down that way I'll let you know.
Great for soaking up oil! Smile
1959 Austin A35
PostPosted: Mon Nov 23, 2009 1:22 pm    Post subject: Reply with quote
Got the spotlights working Smile
And changed the horrible plastic indicator lenses for the proper glass ones, these came with the free spares. I also replaced the split gear gaitor for the new one, and changed the pedal rubbers for new ones, the originals had completely disintigrated.
Before
After
Tried the period radiator muff for size, unfortunately it ran a little hot with it fitted despite being open, so I think I'll sell it and use the money to get a decent grill for the car instead Sad
1959 Austin A35
PostPosted: Mon Nov 23, 2009 1:34 pm    Post subject: Reply with quote
Anyone got any Desmo wing mirror extensions?
I can't see a thing out of my mirrors because they've been positioned too far inboard Sad
1959 Austin A35
Page 2 of 7
