Engine oil for first startup.
First Bedford
PostPosted: Sun Jan 31, 2010 10:53 am    Post subject: Engine oil for first startup. Reply with quote
Hello All, wondering if any advice? Engine has been stood a long time. Don't really want to use use an expensive "classic" oil, after a few minutes running will change oil, I suppose really I'm flushing the engine.
Pete
PostPosted: Sun Jan 31, 2010 12:36 pm    Post subject: Reply with quote
Cheap 20/50 oil from Wilkinson/Supermarkets can be had for less than £5 - this is not graded but good enough. You could ven get way with 15/50 or 15/40 for this exercise
Not a good idea to use flushing oils in old engines that have stood - it is far better to remove the sump scrape out the sediment in there
Rover P2
Morris Mini Traveller Mk2
Ashley
PostPosted: Sun Jan 31, 2010 7:23 pm    Post subject: Reply with quote
I agree. Always a good idea to drop the sump, clean it out and make sure the oil pump pick up is nice and clean, then use any old oil because it will better than the engine was designed for.
Do a few quick oil changes and then use something better.
Ash
First Bedford
PostPosted: Mon Feb 01, 2010 7:06 am    Post subject: Reply with quote
Thanks Ashley and Phil. Sump should drop easily, have a 1m x 1m piece of cork to remake a gasket.
Pete
