Lock without key
Bayliss Thomas
PostPosted: Thu Jun 09, 2011 3:18 pm    Post subject: Lock without key Reply with quote
My 1928 Vauxhall came to me without the key to lock door. I have tried all my old keys lying around with no luck, I do not want to change the lock if this can be avoided, any suggestions please.
PostPosted: Thu Jun 09, 2011 4:12 pm    Post subject: Reply with quote
Often with old door handles it's possible to dismantle them and remove the barrel, exposing the key number, although if your car has a modern repro handle it may not come apart like the old original doorhandle would have done.
victor 101
PostPosted: Thu Jun 09, 2011 6:24 pm    Post subject: Reply with quote
The key number may be stamped on the square shaft, but you may have to try some blanks to find out what series key is needed if its a different pattern to your ignition barrel.
Bayliss Thomas
PostPosted: Thu Jun 09, 2011 6:29 pm    Post subject: Reply with quote
Thanks Rick and Victor, I will let you know how I get on with the problem.
PostPosted: Sat Jun 11, 2011 12:23 am    Post subject: Reply with quote
BT
If you can get the cylinder out and find no number there is another way to get over the problem.
Find a key that leaves the tumblers as close to closed then file off the the tumblers.
OK the lock is less secure with relation to a unique key but at least you have a key that works.
Roger
PS
Try http://www.keysisus.co.uk/
They recut a key for me after I lost mine.
Took him about half an hour to find a blank but I came away with three keys.
Bayliss Thomas
PostPosted: Mon Jun 13, 2011 10:08 am    Post subject: Reply with quote
Perfect, thanks Roger Very Happy
victor 101
PostPosted: Tue Jul 26, 2011 9:56 am    Post subject: Reply with quote
Hi BT, how did you get on with your door lock, did you manage to get a key or key number?
Bayliss Thomas
PostPosted: Tue Jul 26, 2011 2:25 pm    Post subject: Reply with quote
Not been able to make progress unfortunately. Just had the engine works finished and am recovering from the bill for works. Also the car is at another garage for the making and replacing of door hinge pins. Next up is the door lock and then replacement roof covering Crying or Very sad Old cars, don't you just love 'em.
PostPosted: Thu Jul 28, 2011 10:31 pm    Post subject: Reply with quote
Call these people.
Not sure if it can be done, they might be able to make a key with with the lock cylinder.
